cschannuth
FEL Foolishness
Tractorhead
That’s FEL rulez,
the benefit of Hydraulics, you have allway‘s a achievement for a problem.
dclarke
That's a heck of a loader you've built, Craig!  Well done!
cschannuth
Thanks, Denny. I probably need to come up with a quick attach design for the bucket and then a frame for the forks so I don’t have to have the forks out in front of the bucket. It puts a lot of undue stress on the system because those forks are so far out in front of the tractor when they are attached to the front of the bucket. I was impressed with how stable the tractor was with that much weight out front and luckily I only had to move the engine a few feet and set it down.
JoeM
11 hours ago, cschannuth said:
bucket didn’t care for the 500 plus pounds hanging from the forks
Good strong build, handy! :handgestures-thumbup:
I buckled the back top part of mine using the forks transporting a hydro roller that was stabbed under the rear axle from the rear. I bounced a little coming into the shop and she wrinkled a bit.
I always wanted to weld a hook or D ring on the back, outside rear bottom of the bucket that I could use to pick up items with a chain. I thought I could curl the buck up and use it that way. Of course, I will weld it on the next time I need to use it that way. :unsure:
