TroxB
PTO Belt
TroxB
I have a 1996 416H which i was running a 42" rear discharge mower deck (Model  73421). i recently bought a 42" side discharge mower deck model (Model 78345) The PTO drive belt is too short for the side discharge am I missing something or is it a different belt? If the wrong belt what belt should i use? Current belt is a Wheel Horse 108834.Thanks for any help.
8ntruck
The side discharge deck takes a different size belt than the rear discharge belt.  I discovered that when I went from a SD deck to a RD deck last year.
Sorry.  I don't remember the belt numbers or lengths.  Login the manuals section of Red Square for your deck model number.  The manual will probably list the correct belt.
76c12091520h
102742 belt  updates  to 94-2501:handgestures-thumbupright:
gwest_ca
Drive belt 102742 replaced by 94-2501 (1/2" x 103")
Spindle belt 6738 (1/2" x 86")
Garry
peter lena
i have 95 1/2" , for my rear discharge ,and 103" for my side discharge, if you would like to, look over all related moving areas, belt tension pulley, is a common noisy failing point, along with the slide mount nylon points. when you have changed out the belt, a fully mounted drive belt should easily move by hand . pete
TroxB
Thank You!
Bill D
Check tractor supply for belts.  I and others have used them, and they work great.  Bill
