ebinmaine 70,744 #26 Posted November 25, 2020 4 minutes ago, slim67 said: Is that helpful having your splitter setting up higher Eric? Are those 14s? 15s? Yes it sure is. For several reasons. It has better ground clearance for going over our rough terrain. It's more stable because of the wider stance. It rolls far far easier than it did with the itty bitty tires. But maybe most important, it gets the main work beam up off the ground maybe 12 to 14 inches higher and is a real back saver when working with it. They are 15" (205/70R15 ?). Absolutely a worthwhile modification. Share this post Link to post Share on other sites
slim67 2,744 #27 Posted November 25, 2020 4 minutes ago, ebinmaine said: Yes it sure is. For several reasons. It has better ground clearance for going over our rough terrain. It's more stable because of the wider stance. It rolls far far easier than it did with the itty bitty tires. But maybe most important, it gets the main work beam up off the ground maybe 12 to 14 inches higher and is a real back saver when working with it. They are 15" (205/70R15 ?). Absolutely a worthwhile modification. I know the feeling . My Didier is almost ground level with the 4.80-8s and it strains my back after awhile. Share this post Link to post Share on other sites
ebinmaine 70,744 #28 Posted November 25, 2020 44 minutes ago, slim67 said: I know the feeling . My Didier is almost ground level with the 4.80-8s and it strains my back after awhile. This splitter has several mods by both us and the PO to make it more powerful, handle much larger logs, and be more user friendly. Share this post Link to post Share on other sites
slim67 2,744 #29 Posted November 25, 2020 10 minutes ago, ebinmaine said: This splitter has several mods by both us and the PO to make it more powerful, handle much larger logs, and be more user friendly. Lol so is mine. The cylinder is a rod type now and I've replaced the old B&S with a clone motor. Im sure Ill replace something else in the future. Share this post Link to post Share on other sites
ebinmaine 70,744 #30 Posted November 25, 2020 9 minutes ago, slim67 said: Lol so is mine. The cylinder is a rod type now and I've replaced the old B&S with a clone motor. Im sure Ill replace something else in the future. Nice. One of the things I'd like to do to this one is put a better front jack/forward leg on it. We've also talked about welding horizontal splitters onto the vertical part to do twice the cutting. That would be a major time saver because we split ALL our firewood to half the size of most. Share this post Link to post Share on other sites
slim67 2,744 #31 Posted November 26, 2020 1 hour ago, ebinmaine said: Nice. One of the things I'd like to do to this one is put a better front jack/forward leg on it. We've also talked about welding horizontal splitters onto the vertical part to do twice the cutting. That would be a major time saver because we split ALL our firewood to half the size of most. Good idea. If you do that, please start a thread. I'd like to see how it works out. 1 Share this post Link to post Share on other sites
ebinmaine 70,744 #32 Posted November 26, 2020 10 minutes ago, slim67 said: Good idea. If you do that, please start a thread. I'd like to see how it works out. Oh absolutely. Share this post Link to post Share on other sites
Pullstart 64,533 #33 Posted November 26, 2020 “Poppy” likely fits in this thread. Stock pulley setup and only 7 smoky horsepowers, but the tires are more than capable of climbing with zero air pressure in them! I need to drain and flush the transmission, it does the Classic “get stuck in two gears” trick quite often. 1 1 Share this post Link to post Share on other sites
slim67 2,744 #34 Posted November 26, 2020 10 hours ago, pullstart said: “Poppy” likely fits in this thread. Stock pulley setup and only 7 smoky horsepowers, but the tires are more than capable of climbing with zero air pressure in them! I need to drain and flush the transmission, it does the Classic “get stuck in two gears” trick quite often. Pretty sure Poppy would float on water if given the chance. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,744 #35 Posted November 26, 2020 9 minutes ago, slim67 said: Pretty sure Poppy would float on water if given the chance. Sumboddy gotta get the monstah tires and try it!! 1 Share this post Link to post Share on other sites
slim67 2,744 #36 Posted November 26, 2020 19 minutes ago, ebinmaine said: Sumboddy gotta get the monstah tires and try it!! its been done! 1 Share this post Link to post Share on other sites
Pullstart 64,533 #37 Posted November 26, 2020 Maybe with helium in the tires... but they are SUPER heavy! Share this post Link to post Share on other sites
ebinmaine 70,744 #38 Posted November 26, 2020 3 hours ago, slim67 said: its been done! Seen it with full size trucks. Been tried with a garden tractor?? Share this post Link to post Share on other sites
slim67 2,744 #39 Posted November 26, 2020 10 minutes ago, ebinmaine said: Seen it with full size trucks. Been tried with a garden tractor?? There's a new holland on youtube outfitted with terra tires that floated . No garden tractors yet that would be considered garden tractors by our standards but the Mow Money Bolens floated and there is the crypt keeper that tried . Their on youtube also. A kid that ive sold some parts to has a tractor he trail rides on a went into a creek too deep. He floated after the tractor flipped over 1 1 Share this post Link to post Share on other sites
slim67 2,744 #40 Posted November 26, 2020 2 hours ago, pullstart said: Maybe with helium in the tires... but they are SUPER heavy! My advice is start in the shallows! 2 Share this post Link to post Share on other sites
Pullstart 64,533 #41 Posted November 26, 2020 As a kid, I succeeded to float the creek with the Honda 110 three wheeler and balloon tires, but I’m a couple inches bigger now. Share this post Link to post Share on other sites
slim67 2,744 #42 Posted November 26, 2020 1 hour ago, pullstart said: As a kid, I succeeded to float the creek with the Honda 110 three wheeler and balloon tires, but I’m a couple inches bigger now. I remember those 110s. Couldn't kill them. 1 Share this post Link to post Share on other sites
Stormin 9,983 #43 Posted November 26, 2020 4 hours ago, pullstart said: Maybe with helium in the tires... That'd be a laugh. 3 Share this post Link to post Share on other sites
Pullstart 64,533 #44 Posted November 26, 2020 5 minutes ago, Stormin said: That'd be a laugh. The only body of water deep enough to try in... is the pool. I think I’d be exiled for a while! 5 Share this post Link to post Share on other sites
Tractorhead 9,093 #45 Posted November 26, 2020 3 minutes ago, pullstart said: The only body of water deep enough to try in... is the pool. I think I’d be exiled for a while! Maybe the pics it will be worth the discuss after.. 😂 1 1 2 Share this post Link to post Share on other sites
Pullstart 64,533 #46 Posted November 26, 2020 Just now, Tractorhead said: Maybe the pics it will be worth the discuss after.. 😂 Maybe since I do all the pool vacuum work... nobody would notice? 3 Share this post Link to post Share on other sites
slim67 2,744 #47 Posted November 26, 2020 18 minutes ago, pullstart said: Maybe since I do all the pool vacuum work... nobody would notice? Then I say you deserve to be afforded the opportunity to try. That's the perks of being the pool guy. 2 2 Share this post Link to post Share on other sites
Stormin 9,983 #48 Posted November 26, 2020 29 minutes ago, pullstart said: Maybe since I do all the pool vacuum work... nobody would notice? Go on! You know you want too. 1 Share this post Link to post Share on other sites
