seven
Tecumseh hh80
seven
Has anyone ever worked on these it has old style magneto behind flywheel from what I'm finding out parts are real hard to come by ?
ebinmaine
@Stepney might have a bit of knowledge.
I've not messed with one.
I understand some of the ignition pieces can be changed to a more easy to get module.
Stepney
Ignition pieces are quite universal. Most every Teccy from the late 50s into the 80s used the same mag or very close.
What are you looking for exactly?
I have the Master Book. I can take it out later to cross numbers.
seven
Well from what I've found it should be Tecumseh part number 610759 I may let this project go anyway now but if you want to check it out that would be great thxs
Stepney
OH.
You mean a solid state ignition HH80? I thought you were talking about a points ignition engine.
There are a series of tests to prove those parts faulty.. usually it's the external coil on the flywheel that gives trouble.
This piece here?
610759-Tecumseh-Solid-State-Magneto-Tran
Edited by Stepney
seven
Yes that's what I'm looking for .
