chev0545
woodruff key
chev0545
got a key that won't budge in a axle.any ideas?
pfrederi
Chisel under the end....Dremel with a cutoff wheel slice a slot the length of the key down almost to the bottom then collapse the sides in.
  • Like 6
lynnmor
Try tapping down with a punch and hammer at one end in an attempt to rock the key so the opposite end pops up.
Edited by lynnmor
JAinVA
Paul has got the answer for you.The key is cheap to replace.Do not be afraid to destroy it but protect the axle!
Pollack Pete
And when you finally get it out and  put in a new key,coat it with Never-Seeze.
953 nut
I have drilled down the center of the key with progressively larger bits until it was halved. At that point a small punch will get the halves to move. Like Pete said, Never-Seez for the new key and anything you ever want to be able to remove in the future.
th?id=OIP.-6vEzjM6MzFJ0XazyambhQHaHa&pid=Api&P=0&w=300&h=300
  • Like 4
WHX??
Had a few tough ones myself. Soak for a few days with your preferred liquid wrench then the heat wrench. All of the above are great suggestions.
