seven
Engine ?
seven
I bought this really old gem and not sure if it's a Brigs Kohler or Onan? I know it's green like onan ( generator only  of this generating plant manufactured by Onan)
Is what it says on nameplate
953 nut
:confusion-confused:        Can't tell from just that one picture, post up a couple more shots from other sides.
seven
The Tuul Crib
Looks like a briggs
seven
That's what I think too. I can not find anything on it to go off. It does not have the points box outside like you normally see on a Kohler
Achto
I'm going to say that it is an Onan engine, I believe that Onan only used their own engines on their gens. The top of the fan shroud is too rounded off on top for a Briggs. Briggs fan shrouds are a bit more square on top. Is the block cast iron or aluminum? A cast iron Briggs would also have the points in a box on the outside like a Kohler.
bc.gold
Engine is an Onan, how many KVA is the gen head.
Not sure at which horse power Briggs used a mechanical governor, know for sure the 5 hp and under used an air vane,
Edited by bcgold
seven
It's single phase 4 kw (120 volt only) 33 amps . I was wondering if someone put that electric start on it doesn't look to factory 😂
1995 520H+96+97
When that engine was new, plastic starter bendix gear didn't exist.
