Darren Southard
Transmission swap
Darren Southard
Hello all, need some help, as I can't find the answer, or maybe looked right past it.
I have a 1257, 3 speed and found out outer bearing and seal are bad, now I know I could rebuild it I think, seen a lot post and videos, but my question is would a transmission out of a B80, which is a 6 speed which would actually make the tractor a 1267, but are they same size??
Would it be a direct replacement???
Thank you in advance for any help and advice you can recommend.
Darren
stevasaurus
Yes, you can do it that way, but I think the bolt pattern (the 4 bolts that hold the trans to the frame) are not the same pattern.  Your 1257 has the #5058 transmission.  It means it has the bevel gear differential.  Just between you and me, I would rather open the #5058 trans and replace the bad bearing and seal for about $20, then mess around trying to make something fit and then figure out witch drive belt I now need.
   The B-80 has the 8 speed #5091 or the #103907.  The brake drum on your 1257 is mounted on the 11/44 toothed mushroom gear.  The B-80 has the brake drum mounted on the cluster gear shaft.  This means that you would also have to fabricate the brake linkage a little to make it work.  By the way, the 1267 has the #5060 trans.  This is the 10 pinion Limited Slip differential and the brake drum would be in the same place as your 1257.  If you could find a #5060 trans, the brake linkage would be the same, but I still think the bolt pattern is different.
    The #5058 transmission is considered a heavy duty transmission, it has 1 1/8" axles.  The bolt pattern is about 1/4" or more distance between the bolts.
   If you can do any of the above, you can re-build that transmission.  We can help with any way you decide to go.  :orcs-cheers:
  • Excellent 2
Darren Southard
Stevasaurus, thank you for info, I was looking for ease of what to do, and trying to find a direct bolt and play per say, so with transaxel already separated, trans was very hard to turn if at all, once out I filled with Marvel and atf, to soak clean, all leaked out, but as soon as put fluid in trans moved freely which surprised he'll out of me. So I'll probably go that route
Now would you do a complete rebuild or just whats bad, I know don't know what condition things are in inside, but if everything inside is good, should I just do bearing and seal, slap her back together and call a day. Thanks again for your knowledge
Edited by Darren Southard
Misspells
WHX??
Crack it open and clean and inspect. Then you will know what bearings will need to be replaced. Lowell has complete kits or just the separate bearings as needed. I like to go through and replace everything... learned the hard way not to.
https://wheelhorsepartsandmore.com/transmissions.html
Edited by WHX24
stevasaurus
Pardon my manners...Welcome to Red Square.
I'm glad you decided to fix this transmission.  Obviously, you really will not know what you have until you open it.  They are all pretty much bullet proof and worth every penny to fix.  Like Jim said above...open it up, clean it and inspect the bearings.  Every thing is available.  Check out this thread with videos to see what is going on.  This is a sister to your trans...has a pinion differential and 1" axles.  Take some pictures so we can see to help.  I would fix what is bad and replace the 4 seals and gasket.  If it is good , don't worry about it.
Also, use this manual with the videos.  You want Section II.
Darren Southard
Wow!! Thank you so much guys for great info.
My son drove and cut grass with this tractor when he was 5. It was his step uncle's, and years later was given tractor. Right after receiving he was senior and redid motor for senior project, and then went into storage.  Well lost storage and now wanted to see what was wrong with trans. So after reading and deciding to join, (so glad I did) going to make trans right.  Probably take me a while(weeks) but will order parts I know I'll definitely need to have on hand, and go from there.
Hats off to you gentleman
Thank you.
Sincerely Darren
stevasaurus
Darren, wait until you open and clean it to order parts.  The parts can be ordered and had the next day and shipping will be less if you get it all at one time.  Use this same thread to put in pictures and show us your progress.  Knowing now the history behind this horse...this is the right decision.   :occasion-xmas:  Replacing all of the bearings, seals and gasket is around (guessing)  around $170 to $200.  Replacing what is bad should be around $20 to $50.  In other words, if one axle bearing is bad, I would replace the other one.
   I'll make you a list of the bearings and seals and you can check out prices before you tear into it.  Give me a day.  I have some lists for the transmissions, but not for yours.
Darren Southard
Okay, that makes sense, didn't know parts were that quick to get, that's great.... Thank you again so much
And only felt like swap was way to go, was thought tranny with hi-lo would be heavier duty then what is in it now. 😁😁
stevasaurus
Bearings and seals for a #5058 bevel gear transmission.
differential carriage bearing (2) WH #1533  From Lowell
outer axle bearing (2) WH #1526...KOYO #B-1816
outer axle seals (2)  WH #1213...SKF #11050
mushroom gear rh   WH#1532...KOYO #M-16121
mushroom gear lh  WH#1530....KOYO #B-1612
seal brakeshaft  WH#1232.....SKF #9815
cluster gear shaft bearing (2)  WH#1529.....KOYO #M-12121
input shaft  WH#1508 (1)...KOYO #B-1212
input shaft seal  WH#1303....SKF #7410
spline shaft bearing WH#1531...KOYO M-10121
case gasket...#3912
Here ya go...KOYO is the same Torrington numbers.
The low gear range is cool to have if you are running a roto tiller or climbing trees...other then that, most guys do not use the low range.
    You probably do not need to replace the #1533 bearings...2 are around $80, and most of the others may be OK.  Change out all the seals and the gasket.  Lowell has all of it.
ebinmaine
@Darren SouthardSouthard
:text-welcomeconfetti:
Glad you found us!
Would love to see pics of that tractor and all the work you do.
You go ahead and pay real close attention to that fella Steve a saurus that's been giving you info.
He'll steer you in the right direction for sure.
I broke open my first horse transmission two or three years ago and lost all of my intimidation right then and there. They're nice and easy to work on. Rugged as all get-out.
For the most part, if you can figure out which direction to turn a ratchet you'll be able to get one of those fixed up.
When you get to the point of replacing the outer wheel bearing you can use a correct sized socket as a driver if you don't already have a set of them around.
  • Thanks 2
The Tuul Crib
:text-welcomeconfetti:T😎 :rs:
:wwp:
Darren Southard
Will get pictures up as soon as can, probably by weekend, you know how that goes.  Thanks again gentleman!!! It's a real pleasure, finding guys that have the knowledge, but who are willing to share
  • Heart 1
Guest 88vic
You are so correct Darren. There is a ton of people here who want to and will help, theres many many years of knowledge and experience here, I've been around Wheel Horses all my life but I've only begun to scratch the surface. If I get stumped I know where to go and get direction and info. Great bunch of guys here, by the way, Welcome to the Horse gang !
WHX??
I field plow with a 1257 with that tranny Darren and I don't treat it gently... it's bullet proof and if it does break I can fix it! :) BTW I learned most of what I know about :wh: trannies  from the Dino!
Edited by WHX24
  • Excellent 2
roadapples
When you take the tranny or anything else apart take plenty of pictures while you go. Easier to put back together especially if you don't do it right away...
  • Like 5
Darren Southard
WHX24,   wow that is a sweet tractor, looks like what I have just ALOT prettier!!
Darren Southard
Here's tractor day my son brought home from school
Darren Southard
Tried posting a video, don't know if worked but here's tractor in current state
stevasaurus
Start soaking bolts, roll pins, carter pins, hubs and pulleys to help ease of removal.  I like to use diesel to clean the inside, gears, case, etc.  A wire brush and/or wire wheel works wonders also.  Be firm, but gentile.  Shallow side of transmission (input side) goes down when you take out the bolts to open the case.  :occasion-xmas:
ebinmaine
I use a 1.5 or 2 inch wide wood chisel and gently tap around the gasket for the perimeter of entire case to try to break the gasket free a little bit.
Darren Southard
Okay great info thanks for that gentleman. Will do
Darren Southard
Ok guys, started working the old girl today, ya it's been a little while, thought going to be easy, nut after four hours this where I am at
Darren Southard
Broke a hub don't think that big of deal, but hitch pin that goes through case is frozen, was going to grind of both ends and beat down more since it is moving. Didn't want to sacrifice pin but figured a bolt or maybe find another pin down road after together.
ebinmaine
If the hub is already broke and you can obviously cut that off.
Hubs on these normally require a puller and many of us actually use an old hub as the puller mechanism.
That  hitch pin in the rear....
I've had to cut those into 3 pieces to separate the transmission halves.
You can get a hardened pin from TSC or whatever Farm supply.
  • Similar Content
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
