Pullstart 63,359 #1 Posted April 5, 2020 @Stepney @wallfish @jabelman @ZXT @953 nut Any ideas what this is? My father in-law found it in his barn.. 2 Share this post Link to post Share on other sites
ZXT 2,401 #2 Posted April 5, 2020 (edited) Looks like a Barker chain saw.. Probably a C-40. They were yellow though, so maybe this one was sold under a different name It should say what model it is under the bar between the two bolts. Edited April 5, 2020 by ZXT 1 Share this post Link to post Share on other sites
formariz 11,988 #3 Posted April 5, 2020 It is a David Bradley. Share this post Link to post Share on other sites
ZXT 2,401 #4 Posted April 5, 2020 1 minute ago, formariz said: It is a David Bradley. I could be wrong, but I've never seen a DB with that style of handle. Share this post Link to post Share on other sites
formariz 11,988 #5 Posted April 5, 2020 Not sure if the actual manufacturer was David Bradley because Craftsman also had similar saws, but there are David Bradleys out there with that handle. Its missing the bottom part of handle . Share this post Link to post Share on other sites
Pullstart 63,359 #6 Posted April 5, 2020 I took the bar off, no markings. The clutch says “North American Clutch, Cedarburg, WIS” 1 Share this post Link to post Share on other sites
ZXT 2,401 #7 Posted April 5, 2020 (edited) 4 minutes ago, pullstart said: I took the bar off, no markings. The clutch says “North American Clutch, Cedarburg, WIS” I can see Grafton, Wisconsin on the tag on the engine, which makes sense since it's a Power Products (Tecumseh) engine. The only chainsaw that I've found that is red is a Mono chainsaw, but the rope shroud is slightly different. Same with a Roots Lumberjack. Edited April 5, 2020 by ZXT Share this post Link to post Share on other sites
ZXT 2,401 #8 Posted April 5, 2020 (edited) But does it run? Edit: Here' a link to saws that used the AH-81 engine like yours does. http://www.chainsawcollectors.se/phpbb3/viewtopic.php?f=2&t=26276&start=60 Edited April 5, 2020 by ZXT 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #9 Posted April 5, 2020 don't know, but the handle trigger is cool. 1 Share this post Link to post Share on other sites
Anglo Traction 761 #10 Posted April 5, 2020 (edited) I'm inclined to agree with ZXT (Jonah) that it's a Mono. Engine is a Techy AH series of unknown capacity from the pics. Mono appear to have commenced production around 1958 with this model and had several in the range over the years. It also has some characteristics of a Montgomery Wards like the WD-75. Should give you enough to do some net searching..........Nice project to refurbish and make some sawdust !. Regards Edited April 5, 2020 by Anglo Traction 1 Share this post Link to post Share on other sites
Stepney 2,335 #11 Posted April 5, 2020 I had a Mono like that with the little AH Power Products engine .. What a heap of misery. Was OK for cutting a slice of butter for the morning toast I guess. Bahaha. Mine was quite worn out, those Power Products motors always tended to wear out quick. I've owned dozens. 1 Share this post Link to post Share on other sites
wallfish 17,151 #12 Posted April 6, 2020 It's a Mono saw Share this post Link to post Share on other sites
Pullstart 63,359 #13 Posted April 6, 2020 Thanks everyone! Any idea on the value? He has a coworker who collects saws but they have no idea it’s worth. Share this post Link to post Share on other sites
bottjernat1 2,190 #14 Posted April 6, 2020 I agree a barker c40 Share this post Link to post Share on other sites
