TomB
won't shift
TomB
can't shift into gear when engine is running
953 nut
:WRS:
If you do not have the belt guard on the drive belt will not stop when you push in the clutch.
  • Like 3
rjg854
Is the drive belt cover on? Does it just grind?  Please tell us more.
TomB
put a new air filter on and have covers off....shifted fine before can't get it into any gear
  • Confused 1
TomB
thanks...,I'll try your recommendation.
Pullstart
If that doesn’t help... which it should... let us know what model we’re working on :handgestures-thumbupright:
The Tuul Crib
And. Most of all DO NOT force it!!
Not good on the shifter forks!!
:wwp: and
:text-welcomeconfetti:TO :rs:
Ed Kennell
Just curious,   why take the belt guard off to install a new air filter?
The belt guard has two functions;
1.  to protect the operator from injury
2. to support the drive belt when the clutch is depressed. This prevents  the belt  from contacting the engine pulley and allows the belt to stop so the transmission  gears can be shifted.
The tractor transmission can not be operated without the drive belt guard in working order and in place.
Edited by Ed Kennell
  • Like 3
TomB
Didn't take the belt guard off for the air filter.  I need to do some welding so that's why the belt guard is off.  Thanks for your response.
  • Heart 1
953 nut
:text-thankyouyellow:          Now that the mystery is solved please tell us about your :wh: and a bit about yourself.
The Tuul Crib
:text-yeahthat:
Ed Kennell
Was there anything broken or missing on the belt guard?   Some models have belt support tabs have tabs that break  off.
Can we see pictures of your tractor and what needs welding?
