Goldnboy
GT1848 Frame repair
Goldnboy
What do you guys do to repair the frame where the fuel tank bolts in as shown here broken?
Weld/bolt in a new piece of metal?20200321_110114.jpg.4be174a6656c886dbdfd933f954b6f35.jpg
ZXT
Do you have the broken pieces? I'd stop drill any cracks that are present, and weld the missing ears back on with extra reinforcement.
  • Like 6
953 nut
I welded a piece of 1/8 X 3" steel to the front of the fender support and bolted it in with a couple extra bolts.
c-series don
This is exactly what I did. This is a common problem with these models. As a matter of fact the wobbly seat was the main reason I took my Work Horse apart. One thing lead to another and next thing I know it looked like this!
Edited by c-series don
  • Excellent 2
lynnmor
Later models have the mount extend forward to catch two holes on each side.  You would need the newer style cross piece and the console cover that has a jog in it to accommodate the extended part.
ronhatch
C-SERIES DON;   Nice job.  Love the Blue oval and the red belly too!
Edited by ronhatch
Lee1977
I have added 1/8" x 1 1/2" flat to both sides but it was on an 8 speed. I know you would have to cut out a space for the drive belt release. I just used the shifter plate bolts to hold it in place. It's worked for six years.
Edited by Lee1977
Goldnboy
C-SERIES DON
Mine looks  like that almost  now but no paint.
I plan to bolt  in a piece of angle iron for support.
I removed the bottom dust cover due to the rust raised up and prevented  the cam on the brake pedal and motion lever to rotate so the prior owner disassembled it .
Can I leave it out permanently  I think I will be fine cleaning  this area  periodically.
c-series don
I would think that you could leave it out however if you’re going to be mowing with it I’d leave it as this will keep debris out. Here’s mine finished.
Lee1977
On 3/22/2020 at 12:23 PM, Goldnboy said:
C-SERIES DON
I have a 312-8 with out the dust plate and nothing ever get in there or it falls out. It would be easy to use a air compressor to blow it out witjh out the dust plate.
