Sparky
Side shot Saturday... AND SUNDAY !
Andy N.
  • Excellent 5
953 nut
22 hours ago, mikef18 said:
Leaf blower I put together
That blower fan must run rather fast.  Some time back a few people relater the story of their fans blowing apart from spinning too fast. Mine has the same pulley that was used when it was used in the Heat/AC duct and works fine.
I need to paint mine so it will look pretty like yours.
  • Like 4
  • Excellent 2
Handy Don
What RPM did the electric motor run at and what size pulley did it have? Cage blowers like this are designed for higher volume at lower pressures with low-ish RPM.
Lots of electric motors run at ~1,800 RPM vs. the ~3,000 RPM of that Onan
You’ll need to do the math to decide if it’s being overdriven.
953 nut
The motor on the blower was an eighteen hundred RPM unit with about a five or six inch pulley so the fan speed is close to the same now. I understand that if you run these squirrel cage fans at too many RPMs you generate turbulence and reduce the air flow. Mine does a great job as it is set up.
Sparky
  • Excellent 3
