jammankel 24 #1 Posted March 11, 2020 so i blew the seal around the input shaft on the hydro pump how big of a job is it going to be to fix it? and will i have to pull the motor? Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted March 12, 2020 (edited) I think pulling the motor would only be necessitated if it ran for quite an extensive time after the leak started an a foreign substance entered thde system, in which case the whole system would need disassembled and cleaned prior to reassembling and refilling. The engine and pump, none the less has to be separated to replace the seal. Edited March 19, 2020 by "D"- Man Share this post Link to post Share on other sites
jammankel 24 #3 Posted March 26, 2020 how do i separate the engine from the pump? so far i tried pulling it out straight out, i got it to slide about half an inch and then it stopped did i miss anything? Share this post Link to post Share on other sites
pfrederi 21,064 #4 Posted March 26, 2020 To separate the engine from the pump up have to demount the engine .You pull the engine off the pump. Look at the sunstrand manual. Share this post Link to post Share on other sites
