stevebo-(Moderator) 8,351 #1 Posted February 28, 2020 Has anyone modified (shortened) a set of D series hubs to fit on an 8 speed? Is the keyway the same width? Share this post Link to post Share on other sites
Achto 27,761 #2 Posted February 28, 2020 I have never owned any D series hubs. All other hubs use a 1/4" key. Chiming in to get my learn on. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,351 #3 Posted February 28, 2020 My friend VinsRJ just sent me the measurements of an 8 speed hub to a D series hub 8 speed is 5 lug x 4 1/2" D series is 6 lug x 6" It was suggested that I try and source a wheel adapter but not sure where I can find that conversion. Share this post Link to post Share on other sites
pfrederi 17,868 #4 Posted February 28, 2020 D series has 1/4" key but it is an #RX very odd length and height ratio. 1 Share this post Link to post Share on other sites
953 nut 55,771 #5 Posted February 28, 2020 13 hours ago, stevebo said: as suggested that I try and source a wheel adapter I don't think anyone makes a 5 to 6 lug adapter. Option # one would be to go with the "D" hubs if that is the size wheel you plan to run. Option # two would be to have a set made at a machine shop, but that would be too expensive. The key for the "D", GT-14 and 953/1054 is an odd one, but you could use a piece of 1/4 X 1/2 flat stock to make your own. Your C-195 probably has the same hubs and keys as the "D". 2 Share this post Link to post Share on other sites
pfrederi 17,868 #6 Posted February 28, 2020 1 hour ago, 953 nut said: I don't think anyone makes a 5 to 6 lug adapter. Option # one would be to go with the "D" hubs if that is the size wheel you plan to run. Option # two would be to have a set made at a machine shop, but that would be too expensive. The key for the "D", GT-14 and 953/1054 is an odd one, but you could use a piece of 1/4 X 1/2 flat stock to make your own. Your C-195 probably has the same hubs and keys as the "D". Key is #RX I have some if anyone needs them. 1 1 Share this post Link to post Share on other sites
82Caddy 851 #7 Posted February 28, 2020 It'd be easy enough to cut another keyway into the D series hub to match the 8 speed axle assuming you have the same diameter axles if the keyways are indeed different. Cutting down the hub on the non wheel mounting side wouldn't be an issue either with the appropriate machining equipment (or a grinder depending how "finished" you want the product to be). That is if your intended purpose was to be able to run a D series wheel. 2 Share this post Link to post Share on other sites
Pullstart 63,096 #8 Posted February 28, 2020 1 hour ago, 82Caddy said: It'd be easy enough to cut another keyway into the D series hub to match the 8 speed axle assuming you have the same diameter axles if the keyways are indeed different. Cutting down the hub on the non wheel mounting side wouldn't be an issue either with the appropriate machining equipment (or a grinder depending how "finished" you want the product to be). That is if your intended purpose was to be able to run a D series wheel. Just keeping in mind a set screw should be added to where the new key is cut, that’s a great idea! Share this post Link to post Share on other sites
pfrederi 17,868 #9 Posted February 28, 2020 No need for new keyways...all involved here are 1/4" wide. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,351 #10 Posted February 29, 2020 Thanks guys. I will be patient and find a set of D series tires Share this post Link to post Share on other sites
