76c12091520h 3,747 #1 Posted February 26, 2020 (edited) Brand new ! Manufactured by us - 106120 idler support bars. Exact replacement for your worn out , corroded , or missing bars found on most all later model decks. Epoxy coated for durability. $35.00 + shipping. We also have the 107674 / 107675 bushings and washers in stock at all times. Please do not comment on this post. Private message me thru the Red Square messenger or call /text during normal business hours. Edited May 20, 2024 by 76c12091520h 2 5 Share this post Link to post Share on other sites
Don66 1 #2 Posted June 4, 2021 Does this fit the 36" 3-blade mower deck? Share this post Link to post Share on other sites
cleat 6,911 #3 Posted June 4, 2021 Those look awesome. I don't need one right now but glad to see they are being reproduced. Thanks for helping our cause. 1 Share this post Link to post Share on other sites
gmcd 0 #4 Posted April 8, 2022 what is the best time to call and order Share this post Link to post Share on other sites
RaySykes 0 #5 Posted April 18, 2023 are these still available Part Number: 106120? Share this post Link to post Share on other sites
96314-8 0 #6 Posted May 19, 2024 How do I purchase 106120 idler support bar from you Share this post Link to post Share on other sites
76c12091520h 3,747 #7 Posted May 20, 2024 On 5/19/2024 at 8:09 PM, drich1303@comcast.net said: How do I purchase 106120 idler support bar from you Send me a private message..... Share this post Link to post Share on other sites
peter lena 9,051 #8 Posted May 20, 2024 @76c12091520h have also added a flat idler pulley , on the back unsupported side of that belt , over 20 " of unsupported belt bounce ! get a 3 " flat pulley , re grease it , test trial your location , about middle of bounce zone , light push against belt , drill deck hole , like a 3/8 " thread free bearing area , then flat washer both bottom , and top of bolt to deck , elastic lock nut . lots of hours and zero issues . BTW belt bounce is related to bearing lubricant issues , the more bounce you have the , mor collective bearing drag you have . how easily does your deck MOVE BY HAND ? at the mule drive area ? that tells the status of drag on your set up . . should be easy / smooth , pete Share this post Link to post Share on other sites
76c12091520h 3,747 #9 Posted May 20, 2024 On 5/20/2024 at 12:45 PM, peter lena said: @76c12091520h have also added a flat idler pulley , on the back unsupported side of that belt , over 20 " of unsupported belt bounce ! get a 3 " flat pulley , re grease it , test trial your location , about middle of bounce zone , light push against belt , drill deck hole , like a 3/8 " thread free bearing area , then flat washer both bottom , and top of bolt to deck , elastic lock nut . lots of hours and zero issues . BTW belt bounce is related to bearing lubricant issues , the more bounce you have the , mor collective bearing drag you have . how easily does your deck MOVE BY HAND ? at the mule drive area ? that tells the status of drag on your set up . . should be easy / smooth , pete As stated above, please do not comment on these posts... Share this post Link to post Share on other sites
