Bert
Possible axle swap
Bert
Hey gang,
I’ve gotten all the peace’s I need to swap a 520 gear reduction steering setup into my 416, but I’m wanting to use the C195 axle I snagged off eBay. It’s narrower so the tie rods may need modifications but that’s not a big deal :)
My goal is to have a hydro lift tractor that steers easy but doesn't have a wide foot print needing a 48” snow/dozer blade. Also don’t want to use a plow extension.
I have a new extra hydro foot control on the shelf that I’m considering using on this one as well, if it comes together it outta be great worker :wh: Any thoughts or suggestions? C63B22C0-D78E-4BB1-AA72-87EE8D405985.jpeg.07b1c8ad70b0488ed7a56cc6adcab2ea.jpegBFC5FB7C-15D6-437F-83EC-4CB136A274A0.jpeg.5d1fca8a3d2baf2578d7eb0533106764.jpeg
Edited by Bert
  • Like 8
wallfish
Good Idea!
SylvanLakeWH
Sounds like a good idea!
Keep the pics coming as you progress!!!
:handgestures-thumbupright:
peter lena
bert , you can use threaded rod and heim joints for linkage , found that to be very solid and smooth , heim joints are about $ 7 each and fine thread rod about $12 . pete
Racinbob
:text-yeahthat:  I go one step further by cutting a piece of 3/8" ID tubing to fit once I get the length proper for the correct alignment. I like the idea of heim joints and the nest pair of rods will probably use them. :)
  • Excellent 2
Bert
Update, I brought the 195 axle to work and  had roughly 1/4 inch of material removed from the backside area that the axle pin runs through. That got it to fit in a typical :wh: frame, next was to see if the 520 tie rods would fit and as I suspected they are to long. I’ll work on that later, for now here are some pics of the test fit on a 520 parts tractor A0FD638D-EF04-4A75-80B7-73EF17837084.jpeg.79abea8011671f25b0dff3baf2dc5a01.jpeg0ECF1970-0316-4F7A-9EDD-37D831E12E7E.jpeg.243a83563ee8b5cdfca0d3ad481cd8ca.jpegA6F56A42-2769-47DC-A074-F565341C10CF.jpeg.41682e65d13828629f155736a8731b31.jpegor
Pullstart
Those tie rods are awesome!  Cut the r/h threaded side down to size and re-thread... you’re all set!
Bert
Thanks, that's exactly what I did :handgestures-thumbupright:
  • Thanks 2
Bert
As stated above the original 520 tie rods are now shorter, I test fitted every thing and it’s good :happy-partydance:
The next thing will be getting this swapped over to the 416 :)
92DC9BBF-7911-474A-A3C0-1D8A26D1415B.jpeg.83141b17250a6204ad07ed9bb072f997.jpeg7A59D9AC-0D83-43C3-856F-21C427E3A855.jpeg.8c57216547dd973c02f382ff81b998d3.jpeg
  • Excellent 2
Pullstart
I didn’t realize 520 rod ends were ball joint style like that!  That’s automotive tough!
Bert
Yes the factory 520 steering setup is tough, but it has its flaws. I’ve used a front dozer-snow blade on a few 520’s and it sticks out so far that on uneven ground it rubs while in the raised position.
This setup in theory will have the benefits of both, I think :wh: missed an opportunity to offer a gear reduction unit with a straight axle utilizing the heavy 1” spindles:confusion-scratchheadyellow:
The catch is that C 195 axles aren't easily found and for good reason, I would fix one before parting it out and most :wh: fans would probably agree
Edited by Bert
  • Excellent 2
Bert
It’s been awhile sense any progress was posted and that’s because I’ve been working through this shutdown.
I purchased some new wheels from Northern Tool and they fit perfectly and have the correct clearance for the mule drive :greetings-clappingyellow:
CBD1B146-3460-4177-8D88-82A812368B8D.jpeg.edeeb4186e54a1c078886d54d19a5d81.jpeg559B4630-6A99-48F5-B9BF-C25720CF5382.jpeg.ae07c0982e1d436726ba4ed9556dff93.jpeg38DCBA85-CBA9-4C5F-9C8E-331B319CCCAE.jpeg.aa808605e02ef7b6a88c8696cbe8d405.jpegB50ABF2F-CA2E-4393-81C8-879BE862584A.jpeg.6b0fa23d48d55f6803d2bab2029955f6.jpeg
  • Excellent 3
Pullstart
On 2/25/2020 at 7:12 PM, Bert said:
 Any thoughts or suggestions?BFC5FB7C-15D6-437F-83EC-4CB136A274A0.jpeg.5d1fca8a3d2baf2578d7eb0533106764.jpeg
nice S10!
71_Bronco
Looks like you just made it. I was going to suggest measuring everything to make sure the tires dont hit the deck or Mule Drive.
Looking good so far :handgestures-thumbupright:
  • Thanks 2
Bert
Thanks, you bring up a good point about the deck. I'm pretty sure it will clear but don't know for sure yet.
Bert
nice S10!
Thanks, its a fun little beater :auto-swerve:
Bert
I finally got around to swapping all of the pieces on to the 416.
The process was the same as any forward swept/gear reduction job so no need to get into that.
Im pleased to share that this project turned out better than I could have hoped for :D there are no clearance issues or any other negative compromises:dance:
1F48AA35-DF38-41BB-8D67-896C32985E14.jpeg.a1ee4a6f9fa25856c03f2652481f7315.jpegBE5D417E-199B-4E0E-BC1B-ED69CD884488.jpeg.40aa0e8252ae6d6307a85d05c7c29ee5.jpegF85FF4C9-9F3A-4C60-A22E-5873F4A34EE8.jpeg.be18634294ec7f7cfa05d272ba2c62b0.jpeg68404EDB-3784-430F-AD67-5FC8C6F6B1FC.jpeg.04b71270f40ce5448404d62577aa7d45.jpeg
71_Bronco
Looks great!
Only downside would be the increased number of turns for the wheel (due to the reduction), but that would be a personal preference more than anything. Doesnt really effect how it works mechanically.
Edited by 71_Bronco
Bert
1 minute ago, 71_Bronco said:
Looks great!
Thanks,
I personally like the ease of steering even if it’s more turns on the wheel,
this will be ideal for a dozer blade I think.
