redone 45 #1 Posted February 25, 2020 Guys I am loosing it. Last summer I made up a simple eng switch ,with Battery then I for coil.then s for switch. 3 wires,. I have a simple cylinoid with eng post. We're dose my positive on cylinoid go and then to generator start side,. Help me please. ***** getting old. Bill Share this post Link to post Share on other sites
pfrederi 19,241 #2 Posted February 25, 2020 Little hard to follow. is this a Starter/ Generator system? They didn't come with solenoids. To test you ground the field terminal to see if the voltage jumps up to 14.5 +/- Share this post Link to post Share on other sites
redone 45 #3 Posted February 25, 2020 Sorry if miss understood. I am just rigging a simple wiring to get the kohler engine running, I just finish rebuilding this 10 hp with generator starter. I ve used a solenoid to work the ing on order to run on a switch. three wires, one Battery, S for switch.3 to the coil. my question is were do i hookup in this loop with solenoid? its just to test run on the bench is all. I ve forgot how i did it last year....... thank you for your help Share this post Link to post Share on other sites
953 nut 62,975 #4 Posted February 26, 2020 Use this diagram and omit the parts you don't need. Share this post Link to post Share on other sites
redone 45 #5 Posted February 27, 2020 Thank you for your help. i see this problem now. so simple! hope your doing well. Bill Share this post Link to post Share on other sites
