ebinmaine 70,541 #1 Posted February 24, 2020 @stevasaurus asked me to photograph the assortment of axles that I have so he can identify them. Hopefully this will help future readers of this post identify any spare parts they may have laying around or, identify a transmission using the length of the axles taken out. As seen in the picture below, description as follows: Starting on the left hand side we have (3), 1" Axles. The one on the far left as you can see does not have gear teeth in it. Just a hole in one end and a keyway in both ends. That one is 10-5/8" Long. The next two are 1" Axles that came out of Trina's 657. Those have good keyways but both are scored where the wheel bearing was riding. One quite badly. Same 10-5/8" length. Moving to the 1-1/8" Axles we start out at 10-1/8" Long. Then we have 11-1/4" . 11-3/8". 11-5/8". 12" . The last two (without gears) are 13-1/8". The two on the right end (with gears) are a good usable pair from what is believed to be a mid-70s 8-speed. They are 11-5/8" long. 10 5 1 Share this post Link to post Share on other sites
stevasaurus 23,045 #2 Posted February 24, 2020 The thing about axle lengths...no idea until you tear one apart. Using information from members that have torn apart transmissions and knowing what transmissions they tore apart, we were able to make a list. Here you can cross reference axle part #, with transmission # , with what differential, with axle length and figure out what you have or what you need. You will find the IPL's for your horse invaluable here. Use the "Manual Section", find your horse, find the drawing of your transmission, the part # for your axles and cross reference the part # here with the length. It sounds harder then it is....trust me...this is easy and needed to happen. 1" axles:: 1. The first 1" axle on the left is for the #5003 and the #5010 3 piece transmissions. RJ58/9 , 1960-400 & 550, and the 1961-401 10 5/8" 2. The next 2 fit the #5007, #5025, #5046, #5048, #5049 and #5053...all of the two piece"3 speeds". Part II in the transmission manual. 10 5/8" 3. 11 5/8" part #5961 new part #101880 used in (manual) #5086 trannys 4 pinion differential & WH #5052 Sundstrand #3100077...also 4 pinion. 1 1/8" axles:: 1. 10 1/8" part # 108361 used in Eaton transaxles left side. 2. 11 1/8" part # 6451 & 11 3/4" part # 6450 These axles are used in the bevel gear differentials (manual) #5045, #5047, #5051, #5059, #5058 hydro (WH) #5054 Sundstrand #3100077. 3. 11 1/4" part #7203 & 12" part #7202 These axles are used in the 10 pinion Limit Slip differentials (manual) #5060, #5071, #5073 hydro (WH) #5062 Sundstrand #90-4026 4. 11 3/8" ??? 5. 11 5/8" part #102764 used in the #5091 trannys 8 pinion differentials 6. 13 1/8" part #105875 used in the #103907 & #103916 trannys 8 pinion differential 13-1/8" part # 108362 used in Eaton transaxles right side. 7. 14 3/4" part #8054 & 14 1/8" part #8055 These axles are used in the 10 pinion Limited Slip differentials in the (WH) #5070 Sundstrand #90-2062 hydro. NOT A COMPLETE LIST...YET 5 5 Share this post Link to post Share on other sites
Pullstart 64,436 #3 Posted February 24, 2020 Couple of them set up for 1/2” keyways EB? They sure look wallered out! 1 3 Share this post Link to post Share on other sites
ebinmaine 70,541 #4 Posted February 25, 2020 41 minutes ago, pullstart said: Couple of them set up for 1/2” keyways EB? They sure look wallered out! 1/2.... 3/4..... Whatever..... 4 Share this post Link to post Share on other sites
WHX?? 50,615 #5 Posted February 26, 2020 Maybe when all is said and done a member who is a whiz with spread sheets?? 1 1 Share this post Link to post Share on other sites
wallfish 17,454 #6 Posted February 26, 2020 24 minutes ago, WHX24 said: Maybe when all is said and done a member who is a whiz with spread sheets?? Need someone to draw you a map? Once it's done, it's easy to make into a downloadable PDF file 1 2 Share this post Link to post Share on other sites
WHX?? 50,615 #7 Posted February 26, 2020 6 minutes ago, wallfish said: Need someone to draw you a map? Only to the bathroom.... 7 minutes ago, wallfish said: Once it's done, it's easy to make into a downloadable PDF file I can do that if it involves the use of a BFH! 1 2 Share this post Link to post Share on other sites
ebinmaine 70,541 #8 Posted February 26, 2020 12 minutes ago, WHX24 said: I can do that if it involves the use of a BFH! I gotta 16 pound sledge here.... Share this post Link to post Share on other sites
WHX?? 50,615 #9 Posted February 26, 2020 6 minutes ago, ebinmaine said: I gotta 16 pound sledge here.... Psst ... I got a 30 lb maul.... 1 Share this post Link to post Share on other sites
Skipper 1,789 #10 Posted September 11, 2021 C195, 1 1/8 axles. 109753, 15 7/8 long, 109754, 12 7/8 long. 1 2 Share this post Link to post Share on other sites
ebinmaine 70,541 #11 Posted July 9, 2023 Only thing I don't see at this point is GT14 or 953/1054. Share this post Link to post Share on other sites
ebinmaine 70,541 #12 Posted July 9, 2023 On 2/25/2020 at 7:31 PM, wallfish said: Once it's done, it's easy to make into a downloadable PDF file Is this list complete enough that you'd like to have Trina make up the sheet? Share this post Link to post Share on other sites
squonk 42,450 #13 Posted March 8 (edited) @stevasaurus I have a 1 1/8" axle that is 12" long. Any ideas ? It was taped to another axle 11 1/4" long like for a 5060. Could one side be 11 1/4 and the other side 12" EDIT OK I see the 12" listed. Never mind. Edited March 8 by squonk 1 1 Share this post Link to post Share on other sites
