toroman04
Choke cable help
toroman04
Hi all, I picked-up a 72 (was told it was a 74) after doing some research on it, anyway I need some help on a picture/part # for the choke cable. I have a Charger 10 automatic with a Kohler K241-46636
Any help would be appreciated! I have never owned a Wheel Horse before so I am new to this! I traded a snowmobile trailer for it.... It did not run, but did come with extra parts like: carb, ign. switch, starter, coil, front rims and tires, rear fender and a weight box. No mower deck but does have a plow. I seem to think I got the better end of the deal!
ebinmaine
Welcome aboard!
You should have a slide style cable.
You got a great deal.... But I'm not much for snowmobiles....:D
Get that Charger up and cooking and you'll have a great little plow rig!!
Edited by ebinmaine
Corrected cable type
Achto
:WRS:
Here is one link for a choke cable.
http://www.psep.biz/store/toro_mower_cables.htm
Edited by Achto
oliver2-44
:text-welcomeconfetti::wwp:
SylvanLakeWH
953 nut
:WRS:
Your choke cable should run under the shroud that covers the flywheel. The spiral sheath of the cable will attach to a fixture on the front of the shroud and the cable itself will have a "Z" bendin the end of it attaching to the choke.
Edited by 953 nut
fat finger
toroman04
here are a few pictures, what's throwing me off is what you see here (dash pic) Looks like same as throttle cable .... but is it actually a pull/push as there is a spot there or just a screw missing.
rjg854
That choke lever is the same style as the throttle
Oldskool
Welcome.  I think you ended up with the better half of the trade.
toroman04
I sure think i did get the better deal! lol though it has no spark and didn't run.... not a problem for me! I need to get a few more things for it yet.... air filter, fuel filter, new plug, drive belt and choke cable.
ebinmaine
:text-yeahthat:
stevasaurus
Here is a 1972 Raider 10...yours should be the same.  You can see the choke handle in this picture.  Contact A-Z Tractors...one of our vendors in the vendor section.  He should be able to help with the choke cable and more.
Welcome to Red Square
toroman04
Thanks All! i'll contact them! Now I need to get a drive belt and figure out the part # for the trans filter.... all I can red is 79-52??? lol
Edited by toroman04
ebinmaine
Hydraulic transmission filter is likely a Napa 1410.
Retired Wrencher
toroman04 :WRS: As you can see lots of help here. Enjoy the site.
toroman04
Thanks for all the help so far! I got a number to contact tomorrow for the part! Got a new plug, air & pre-filter along with a drive belt put on, now time to drain the transmission change filter and re-fill
C_hasbeen
Well you have a busy schedule once you get your parts in hand.
peter lena
toroman04, in addition to your cable mounting / routing , make sure that you , hang and oil drip that cable , before use, ensuring its smooth function. another thing is to add more cable clamps to its routing tracking , that will insure its solid movement for use. just because clamps were not there , does not mean that you cannot add more for , smooth movement , pete
peter lena
toroman04, see that you are going to change that trans fluid, good idea to cut off the shift boot with a razor blade and replace it , usually the cause of water getting in the trans. when you replace the boot  lubricate the shifter shaft with grease for ease of installation. pete
toroman04
Hi Peter lena, It is a hydro, so is that/there a boot on that? I haven't seen one under there.
toroman04
Engine oil along with trans fluid & filter done! Time to run thru the wash and clean frame!
