Rickenbacker53 0 #1 Posted February 16, 2020 (edited) My Auger Chain on My Toro Single stage Snow Thrower is worn enough I am out of adjustment : A New one is $64 to $86.00 . Depending on where you buy it. Seriously ?? For a Chain? Is there any reason I can't just have a hardware store make me a Chain that length for $15.00 ? Edited February 16, 2020 by Rickenbacker53 Share this post Link to post Share on other sites
rjg854 11,350 #2 Posted February 16, 2020 Go to tractor supply and buy #40 chain, a couple of extra links and have enough chain to do again. BTW 4 2 Share this post Link to post Share on other sites
Rickenbacker53 0 #3 Posted February 16, 2020 26 minutes ago, rjg854 said: Go to tractor supply and buy #40 chain, a couple of extra links and have enough chain to do again. BTW Where does #40 Come from? Share this post Link to post Share on other sites
rjg854 11,350 #4 Posted February 16, 2020 Size of the chain Share this post Link to post Share on other sites
peter lena 8,583 #5 Posted February 16, 2020 probably from china , like everything else. btw , do you LUBRICATE THAT DRIVE CHAIN ? recommend lubriplate chain and cable spray , keep it wet with lube and you failure rate will disappear. pete Share this post Link to post Share on other sites
Ed Kennell 38,025 #6 Posted February 16, 2020 Don't forget the connector links to join the chain after cutting to the same number links as the old one. There is a you tube video showing the proper way to assemble the connector link relative to the travel direction of the chain. 1 Share this post Link to post Share on other sites
Achto 27,509 #7 Posted February 16, 2020 (edited) Here's a link to a video on installing the master link. Edited February 16, 2020 by Achto 1 1 Share this post Link to post Share on other sites
peter lena 8,583 #8 Posted February 17, 2020 ACHTO, good simple follow up on that, as far as the pricing of a lot of w/h parts , its killing itself . if you have a related # its easy to find just about anything. i would not even consider paying a price like that , when T/S has it in stock for much less. thanks again for the installation flick, pete 1 Share this post Link to post Share on other sites
Rickenbacker53 0 #9 Posted February 18, 2020 On 2/16/2020 at 8:07 PM, peter lena said: ACHTO, good simple follow up on that, as far as the pricing of a lot of w/h parts , its killing itself . if you have a related # its easy to find just about anything. i would not even consider paying a price like that , when T/S has it in stock for much less. thanks again for the installation flick, pete Thanks Share this post Link to post Share on other sites
