snowhound 105 #1 Posted February 15, 2020 Did Wheel Horse have solid links to replace the chains on the lift mechanism so you could apply down pressure on a snow blade or mid mount grader. If so does anyone have the dimensions? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted February 15, 2020 Click on the picture so you can read the notes. I made a different lift link for the grader blade but but not sure it was necessary. The 3/8" pins are 8-3/4" center to center and welded on in opposite directions. Garry 2 1 Share this post Link to post Share on other sites
snowhound 105 #3 Posted February 15, 2020 Thanks for the reply that's exactly what I need. Share this post Link to post Share on other sites
ebinmaine 67,292 #4 Posted February 15, 2020 @J854D Above is the bulletin giving you the information you requested. I've seen links with the corners cut at a 45 producing a similar shape to the round ones above. I think my link is a hair shorter but it won't matter much.... 1 Share this post Link to post Share on other sites
J854D 137 #5 Posted February 16, 2020 Thanks @ebinmaine! That’ll work! -JD- 1 Share this post Link to post Share on other sites
