Currys Garage 0 #1 Posted February 15, 2020 After i rebuilt hh 80 tecumseh on customers wheel horse work horse it won/t fire. No spark I adjusted ignition module gap to specs.Even replaced ign. module still no spark.Any help would be appreciated. Share this post Link to post Share on other sites
ZXT 2,401 #2 Posted February 15, 2020 31 minutes ago, Currys Garage said: After i rebuilt hh 80 tecumseh on customers wheel horse work horse it won/t fire. No spark I adjusted ignition module gap to specs.Even replaced ign. module still no spark.Any help would be appreciated. Did you do anything else to the tractor, wiring wise? Same ignition switch? First thing I would do is disconnect the kill wire from the coil and see if you have spark. 1 Share this post Link to post Share on other sites
ebinmaine 67,266 #3 Posted February 15, 2020 Bench test the coil? Continuity test the wiring? Check and clean the points? Share this post Link to post Share on other sites
pfrederi 17,663 #4 Posted February 15, 2020 There are no points, no bench test. Manual has you check everything else then replace the module. Two modules no spark I agree with ZXT make sure the kill wire isn't grounded 3 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #5 Posted February 15, 2020 to 1 Share this post Link to post Share on other sites
Ed Stoller 19 #6 Posted February 22, 2020 Did you replace the spark plug with a new Champion? If you did, try a different plug. Several of us had new Champions that would not fire. Clean the flywheel magnets and tighten up the air gap. I am not sure what ignition you have, but you might check my web site, www.enginesandmagnets.com, if it is a Solid State Ignition like on most HH120s.edstoller at earthlink dot net. I have also been working on a new ignition made from a GM LS2 ignition coil and a modified GM PC2 crank sensor that looks very promising. 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #7 Posted February 22, 2020 59 minutes ago, Ed Stoller said: Did you replace the spark plug with a new Champion? If you did, try a different plug. Several of us had new Champions that would not fire. Clean the flywheel magnets and tighten up the air gap. I am not sure what ignition you have, but you might check my web site, www.enginesandmagnets.com, if it is a Solid State Ignition like on most HH120s.edstoller at earthlink dot net. I have also been working on a new ignition made from a GM LS2 ignition coil and a modified GM PC2 crank sensor that looks very promising. I booked marked your site, looks interesting 1 Share this post Link to post Share on other sites
D_Ram 14 #8 Posted July 11, 2020 On 2/14/2020 at 7:59 PM, Currys Garage said: After i rebuilt hh 80 tecumseh on customers wheel horse work horse it won/t fire. No spark I adjusted ignition module gap to specs.Even replaced ign. module still no spark.Any help would be appreciated. Did you determine the cause? Share this post Link to post Share on other sites
ebinmaine 67,266 #9 Posted July 11, 2020 47 minutes ago, D_Ram said: Did you determine the cause? The OP hasn't signed in since February 15th so likely hasn't even seen posts #6, on... Share this post Link to post Share on other sites
