seven 202 #1 Posted February 10, 2020 Wondering if on my charger 12 with plow blade if there would be enough down pressure to lift the front tires off the ground ? Currently I'm afraid to try it because I know if I do the yoke that goes into the cylinder shaft will pull out again. The threads are partially stripped Share this post Link to post Share on other sites
953 nut 55,093 #2 Posted February 10, 2020 If the system is in good condition and you are using the proper solid lift linh it will lift the front tires. 2 Share this post Link to post Share on other sites
wallfish 16,985 #3 Posted February 10, 2020 It should easily be enough power to lift the front off the ground 1 Share this post Link to post Share on other sites
pfrederi 17,674 #4 Posted February 10, 2020 4 hours ago, seven said: Wondering if on my charger 12 with plow blade if there would be enough down pressure to lift the front tires off the ground ? Currently I'm afraid to try it because I know if I do the yoke that goes into the cylinder shaft will pull out again. The threads are partially stripped I had the yoke on the end of the hydro cylinder shaft unscrew itself...at the far end of the driveway of course. Drilled and tapped it for a set screw. Not ideal as it damages the threads but less damaging than welding. 2 Share this post Link to post Share on other sites
seven 202 #5 Posted February 11, 2020 Good deal wasn't sure must be a 2 way cylinder then power up power down I'm going to take it then and have it rethreaded cousin is a mashinest Share this post Link to post Share on other sites
