seven
Hydrolic cylinder?
seven
Wondering if on my  charger 12 with plow blade if there would be enough down pressure to lift the front tires off the ground ? Currently I'm afraid to try it because I know if I do the yoke that goes into the cylinder shaft will pull out again. The threads are partially stripped
953 nut
If the system is in good condition and you are using the proper solid lift linh it will lift the front tires.
wallfish
It should easily be enough power to lift the front off the ground
pfrederi
I had the yoke on the end of the hydro cylinder shaft unscrew itself...at the far end of the driveway of course. Drilled and tapped it for a set screw.  Not ideal as it damages the threads but less damaging than welding.
seven
Good deal wasn't sure must be a 2 way cylinder then power up power down I'm going to take it then and have it rethreaded cousin is a mashinest
