76c12091520h 3,692 #26 Posted March 3, 2022 2 hours ago, khawk said: I am looking for a 1611 pulley. I have one, private message sent. Share this post Link to post Share on other sites
conehead 14 #27 Posted March 13, 2022 Hello, I am looking for gage wheels for my side discharge mower deck. I have an 1988 312-8. The number off the mower deck is 0542MS05 (first line) 74555 (second line). I need the wheels and new axil bolts. Thanks! Conant Share this post Link to post Share on other sites
76c12091520h 3,692 #28 Posted March 14, 2022 5 hours ago, conehead said: Hello, I am looking for gage wheels for my side discharge mower deck. I have an 1988 312-8. The number off the mower deck is 0542MS05 (first line) 74555 (second line). I need the wheels and new axil bolts. Thanks! Conant Private message sent Share this post Link to post Share on other sites
Bob Lister 142 #29 Posted April 15, 2022 I have a mid 80's 312A with 37" deck and need the correct blades The only numbers I have from the deck are 0537SC01 62670 Thanks Bob Share this post Link to post Share on other sites
76c12091520h 3,692 #30 Posted April 15, 2022 8 hours ago, Bob Lister said: I have a mid 80's 312A with 37" deck and need the correct blades The only numbers I have from the deck are 0537SC01 62670 Thanks Bob PM sent Share this post Link to post Share on other sites
Michael Evans 0 #31 Posted May 5, 2022 Looking for quick hitch assembly #6587 Share this post Link to post Share on other sites
drewd 55 #32 Posted May 10, 2022 Hello, I am referbing a 42" SD deck and can read some of the info on label. Deck 05-42MS05. I need the center double stack pulley 110148 (hole looks like 5/8"). Also need bearings. The shafts are thicker where the blades attach but thinner above that. Can you confirm as I'm not sure if I have a Frankenstein deck or if these are as they came! I believe the bearings are #109966 (again looking like 5/8") Thanks! Share this post Link to post Share on other sites
Michael Evans 0 #33 Posted May 10, 2022 10 minutes ago, drewd said: Hello, I am referbing a 42" SD deck and can read some of the info on label. Deck 05-42MS05. I need the center double stack pulley 110148 (hole looks like 5/8"). Also need bearings. The shafts are thicker where the blades attach but thinner above that. Can you confirm as I'm not sure if I have a Frankenstein deck or if these are as they came! I believe the bearings are #109966 (again looking like 5/8") Thanks! This is the shaft I guess you'd call it that I need. The front that connects to the frame of the tractor. The part number for the shaft"called quick hitch assembly" is #6587. I was able to source the triple pulley, and new bearings are available to just purchase. Center bore of pulley with bearings is 3/4". There's a bolt threading into the shaft of the pulley side. And a snap ring on the opposite side. I believe the larger diameter sections are sleeves but not sure. If you have the whole thing with the pulley I'd take everything. Just to make life easier. The tractor it's on is a 857. (1967 small frame). Share this post Link to post Share on other sites
76c12091520h 3,692 #34 Posted May 10, 2022 6 hours ago, drewd said: Hello, I am referbing a 42" SD deck and can read some of the info on label. Deck 05-42MS05. I need the center double stack pulley 110148 (hole looks like 5/8"). Also need bearings. The shafts are thicker where the blades attach but thinner above that. Can you confirm as I'm not sure if I have a Frankenstein deck or if these are as they came! I believe the bearings are #109966 (again looking like 5/8") Thanks! Private message sent Share this post Link to post Share on other sites
76c12091520h 3,692 #35 Posted May 10, 2022 6 hours ago, Michael Evans said: This is the shaft I guess you'd call it that I need. The front that connects to the frame of the tractor. The part number for the shaft"called quick hitch assembly" is #6587. I was able to source the triple pulley, and new bearings are available to just purchase. Center bore of pulley with bearings is 3/4". There's a bolt threading into the shaft of the pulley side. And a snap ring on the opposite side. I believe the larger diameter sections are sleeves but not sure. If you have the whole thing with the pulley I'd take everything. Just to make life easier. The tractor it's on is a 857. (1967 small frame). Pm sent Share this post Link to post Share on other sites
BigJim 1 #36 Posted May 26, 2022 would you have the gear for a 7-1261 50" tiller part #100429 15 tooth. Share this post Link to post Share on other sites
Joeuncle 0 #37 Posted June 3, 2022 Hello, Do you have any 7416 covers left? If so what is your price with shipping? Thank you Kevin Myers Share this post Link to post Share on other sites
RidersofRohan 0 #38 Posted September 12, 2022 Looking for the nylon engine fan on the Kholer M10 on my 1987 310-8. Share this post Link to post Share on other sites
Eli 8 #39 Posted March 23, 2023 Looking for 3/4 Spindle Shafts (#104890) for a 1976 42" side discharge. Thank you! Share this post Link to post Share on other sites
76c12091520h 3,692 #40 Posted March 23, 2023 (edited) 7 hours ago, Eli said: Looking for 3/4 Spindle Shafts (#104890) for a 1976 42" side discharge. Thank you! Private message sent Edited March 23, 2023 by 76c12091520h Share this post Link to post Share on other sites
Easton Rich 430 #41 Posted April 11, 2023 Do you by any chance have hour meter gauges for an 88' 418-A Share this post Link to post Share on other sites
76c12091520h 3,692 #42 Posted April 11, 2023 21 hours ago, Easton Rich said: Do you by any chance have hour meter gauges for an 88' 418-A Private message sent Share this post Link to post Share on other sites
Phil53 7 #43 Posted May 8, 2023 I need a PTO bake assembly for a 310-8 wheel horse I think the part number is 110665 if you have one please let me know the cost and how to oeder one Thanks Phil Share this post Link to post Share on other sites
76c12091520h 3,692 #44 Posted May 8, 2023 8 hours ago, Phil53 said: I need a PTO bake assembly for a 310-8 wheel horse I think the part number is 110665 if you have one please let me know the cost and how to oeder one Thanks Phil Private message sent Share this post Link to post Share on other sites
The Kidd 5 #45 Posted May 9, 2023 I need a motor to deck belt for a Wheel Horse 312-8 with a 42” side discharge deck. Share this post Link to post Share on other sites
76c12091520h 3,692 #46 Posted May 9, 2023 2 hours ago, The Kidd said: I need a motor to deck belt for a Wheel Horse 312-8 with a 42” side discharge deck. Private message sent Share this post Link to post Share on other sites
briand212 0 #47 Posted May 19, 2023 Hi .. I am looking for a front rim for my d-180, 8in rim with 3/4 spindles Thanks Share this post Link to post Share on other sites
