balconio
Stank exhaust
balconio
Looking for opinions here. I have two 312-8s from the late 80's both with over 1400hrs on M12 engines. They both run great, start without hesitation in any weather and neither seems to burn oil or anything like that. But the exhaust stinks badly, smells like they're running too rich maybe.
When I start them on full choke I see some gray/black smoke as expected and they want the choke to be put full off almost immediately after starting even in freezing temps (again they seem rich). Once the choke is off I don't see any gray/black smoke and they have good power with no surging stalling or backfiring.
My question is, should I try to mess with the fuel mixture? Do valves start to seal poorly over time? Is this just how it is with a well worn Flathead and do you guys notice the same out of your machines? I'm thinking about running a rear exit exhaust when I build one into a mud mower and high stacking the worker horse just to get the stink away from the operator.
ebinmaine
If an M12 carb is as easy to rebuild as a K carb I'd start with that...
tunahead72
3 minutes ago, balconio said:
… My question is, should I try to mess with the fuel mixture? ...
I would.  It's an easy thing to try, and it might solve your problem.  If it doesn't, you can keep looking.
Do you have manuals for your engines?
balconio
No I don't think I have manuals but I'm sure I can find it online and agree it's worth a shot. Sounds like you guys don't find your machines to have a queasy level of hydrocarbon emissions... The one makes my whole jacket stink after blowing off the driveway.
ebinmaine
Oh yeah....
Way high....
The Tuul Crib
That many hours l would definitely
re- adjust the valves rebuild the carburetor and give it a good complete tuneup.
lynnmor
You don’t want a Köhler running lean, that is a good way to burn valves.  There is a Cub Cadet dealer in my area that smoked many an engine with his lean adjustments.
Digger 66
Yes ^
Especially if the valves & seats were designed for leaded fuel .
953 nut
I would say a little prayer of thanks and move on.         Running a little rich is a good thing for your engine's longevity.     A little Seafoam in the gas couldn't hurt.
Pollack Pete
I'm with 953-Nut...….if it ain't broke,don't fix it.Do they use any oil at all? Burning even a trace of oil will make the exhaust stink to high heaven.
Retired Wrencher
Did you look at the spark plug to see how it is running? A tan color or a very  little on the white side.
pfrederi
Many Magnums came with Walbro Fixed jet carbs Is yours one of those?  Cleaning is about it as there is no high speed adjustment.  Frankly they usually act up by getting to lean (crud build up blocking the jet)
Lee1977
Mine don't have both adjustmentson on the carb. You can remove the dirt and trash but it is what it is. Best to use nonethnoal gas.
tom2p
replace the carb with programmed electronic fuel injection and install new exhaust system with catalytic converter and say goodbye to stink jacket
or maybe some bean oil will provide better aroma ...
Edited by tom2p
