oldredrider
953 throttle
oldredrider
Picked up a crate of Wheel Horse parts. Included was a disassembled K-241 for a 953. Putting the engine back together and have gotten to the point where I need to know how the throttle is routed/hooked up to the engine.
I have tons of engine parts so variations are not a problem.
What I would like to see are pics of the proper routing of the throttle cable and governor hook up.
Would like this motor to be a plug and play for anyone interested in it.
Thanks for any assistance.
953 nut
Here you go.
SylvanLakeWH
On a C 105...Hope these help...
oldredrider
4 hours ago, 953 nut said:
Here you go.
Thanks Richard. That's exactly what I was looking for!
Edited by oldredrider
oldredrider
After digging through all the parts, I came up with these guys. Apparently,  this engine uses a shorter linkage rod which hooks up to the throttle cable like this:
Notice the throttle cable clamp is mounted to the shroud.
953 nut
That clamp is for the choke cable, the one on the breather/valve cover is for the throttle. Should work fine.
oldredrider
Not shown in the pic but there is a clamp for the choke cable mounted in the conventional spot. The throttle cable mounted in the shroud clamp lines up perfectly with the linkage angle thingy.
If you look closely at your pic, there is a mounting hole for a clamp on your shroud.
