The Tuul Crib 7,338 #1 Posted February 8, 2020 Just got my Block back from the machine shop today along with the crank.The guy that did this for me is well known in hot Rod Magazine for his work on V-8 engines. When I got there today to pick it up he was working on a racing engine which was a 408 chevy engine. I had my 321 bored .010 over and the crank ground and polished to .010 under. He also ground the valve seats as well. He only charged me 80 bucks cash no ticket. The guy is 80 years old and still going!! 4 9 3 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #2 Posted February 8, 2020 The cylinder had 3 1/2 thousands of an inch wear in the belly of the bore as well as the crank which had 3 1/2 thousands wear out of round also, Not bad for a 40 year old motor 1 1 Share this post Link to post Share on other sites
Achto 28,386 #3 Posted February 8, 2020 50 minutes ago, The Tool Crib said: He only charged me 80 bucks cash no ticket That would be a deal at twice the price!! It looks great so far. 1 Share this post Link to post Share on other sites
oliver2-44 10,148 #4 Posted February 8, 2020 That is a great price, I've found a dirt bike shop that will bore the block for $50,$60, but no one to grind a crank. I'll be following along as i also have a k321 to reassemble. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #5 Posted February 8, 2020 I was there when he ground the crank not sure the name of that machine that he did this on but he had a 24 inch stone will behind a machine or lathe . That machine was built in 1967. Share this post Link to post Share on other sites
pacer 3,175 #6 Posted February 8, 2020 Theres no one near me to do small engines, - well a couple said they could probably bore one but the kicker is what tool crib was describing about the stone to do the crank. Had a couple told me they could do it but he didnt have a stone that was small/thin enough to fit that small size, just wasnt enough calls to justify getting set up for it...... 1 Share this post Link to post Share on other sites
ZXT 2,401 #7 Posted February 8, 2020 $80 to bore a cylinder, grind the seats, and turn a crank? That's insanely cheap! For that, I'd have every Kohler on the place done. Excellent deal. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #8 Posted February 8, 2020 Thats my plan. Hes 80 years old and has arms like poppeye! I have two 16 s and a 12 to do soon while he can. 3 Share this post Link to post Share on other sites
Howie 899 #9 Posted February 8, 2020 Think the last crank I had done here cost me 65. Used to get it done for $45 but guy retired and they did not hire someone else and have since closed. 1 Share this post Link to post Share on other sites
8ntruck 7,293 #10 Posted February 8, 2020 Great price. Looks like he did a pretty good job. Anybod else think that a 3 angle valve job would be a good idea in a Kohler? Share this post Link to post Share on other sites
76c12091520h 3,730 #11 Posted February 8, 2020 I have them done on all my flatheads, no complaints Share this post Link to post Share on other sites
richmondred01 2,287 #12 Posted February 8, 2020 Since I retired I rebuild 3-4 k and magnum series per month. Ive used the same machine shop for decades and crank grinding is 75, boring is 80 valves 45. so 80 for the entire job is outstanding. Share this post Link to post Share on other sites
lynnmor 7,515 #13 Posted February 8, 2020 11 hours ago, 8ntruck said: Anybody else think that a 3 angle valve job would be a good idea in a Kohler? In order to get the correct diameter and width of the sealing surface, the adjacent surfaces need to be ground on any engine. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #14 Posted February 8, 2020 Had to re-order a new 10 under connecting rod Because the one that I had was no good. No loss because it was in a batch of parts that was given to me. So now I have to wait until I get it on Wednesday. So today I thought I would do some painting on some parts and tins. Share this post Link to post Share on other sites
pfrederi 18,233 #15 Posted February 8, 2020 2 minutes ago, The Tool Crib said: Had to re-order a new 10 under connecting rod Because the one that I had was no good. No loss because it was in a batch of parts that was given to me. So now I have to wait until I get it on Wednesday. So today I thought I would do some painting on some parts and tins. Was it damaged or just miss-sized??? Share this post Link to post Share on other sites
The Tuul Crib 7,338 #16 Posted February 8, 2020 3 minutes ago, pfrederi said: Was it damaged or just miss-sized??? The rod when measured at the machine shop he told me that one side was wider than the other. Which means somebody had tried to turn it or did Something to it to make it out of whack. Kind of sucks because it was a brand new one. Or it could've been screwed up when it was made who knows! 1 1 Share this post Link to post Share on other sites
8ntruck 7,293 #17 Posted February 9, 2020 13 hours ago, lynnmor said: In order to get the correct diameter and width of the sealing surface, the adjacent surfaces need to be ground on any engine. Yup. I was wondering if any gains from the improved low lift flow a 3 angle valve job produces would worth the effort and expense. Share this post Link to post Share on other sites
Stormin 9,983 #18 Posted February 9, 2020 On 2/8/2020 at 2:17 AM, The Tool Crib said: I was there when he ground the crank not sure the name of that machine that he did this on but he had a 24 inch stone will behind a machine or lathe . That machine was built in 1967. Cylindrical Grinder, Randy. I used one a few?? years ago during my apprenticeship as a toolmaker. Not for cranks though. Share this post Link to post Share on other sites
lynnmor 7,515 #19 Posted February 9, 2020 10 hours ago, 8ntruck said: Yup. I was wondering if any gains from the improved low lift flow a 3 angle valve job produces would worth the effort and expense. It ain't about flow, although some very slight gains might be realized, it is about getting the correct pressure on the seat. If the contact area is too wide, there will be less pounds per square inch leading to leakage. If the contact area is too small, there may be insufficient heat transfer from the valve to the block leading to burnt valves. 3 Share this post Link to post Share on other sites
lynnmor 7,515 #20 Posted February 9, 2020 2 hours ago, Stormin said: Cylindrical Grinder, Randy. I used one a few?? years ago during my apprenticeship as a toolmaker. Not for cranks though. The engine shops use a special kind of cylindrical grinder that makes the offset for rod journals much easier to set up. A standard cylindrical grinder doesn't have a tailstock that can accommodate the swing for the rod journals. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #21 Posted February 9, 2020 So I'm getting bored sitting here waiting for the new rod to arrive for this motor. I'm thinking about PTO patina . Now say that a few times without stumbling! Man I got to get a life!! Is it spring yet? 64 and first sun shine in Three weeks!! that the temp here not my age! 1 Share this post Link to post Share on other sites
Stormin 9,983 #22 Posted February 9, 2020 Paint it silver. Go nicely with the black engine. Have a look at my Black Horse. Share this post Link to post Share on other sites
pfrederi 18,233 #23 Posted February 9, 2020 17 minutes ago, The Tool Crib said: So I'm getting bored sitting here waiting for the new rod to arrive for this motor. I'm thinking about PTO patina . Now say that a few times without stumbling! Man I got to get a life!! Is it spring yet? 64 and first sun shine in Three weeks!! that the temp here not my age! I gave up waiting for the connecting rod from I save tractors that I ordered 15 January. got one from Ebay bakt4kids 86,000 reviews 99.8% positive., Ordered on Wednesday 5th delivered Saturday 8th. Free shipping. Made in Taiwan..probably same factory. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #24 Posted February 9, 2020 9 minutes ago, pfrederi said: I gave up waiting for the connecting rod from I save tractors that I ordered 15 January. got one from Ebay bakt4kids 86,000 reviews 99.8% positive., Ordered on Wednesday 5th delivered Saturday 8th. Free shipping. Made in Taiwan..probably same factory. That's funny because that's exactly where they're coming from. I had to order it Friday night when I found out the one I had was no good but It's all good !! It'll be here by Wednesday gives me time for other things anyway! 1 Share this post Link to post Share on other sites
pfrederi 18,233 #25 Posted February 9, 2020 Interesting. Most good machine shops will measure and tell you what you need to order...but will not actually bore or grind until they get the new piston/ rod to make sure it is done correctly. Share this post Link to post Share on other sites
