Psychonova68
Commando 8 transmission help
pfrederi
Take a break have an adult beverage and watch this video
  • Heart 2
Psychonova68
I don't see a bolt or anything on the brake, what am I missing? And should I try to get the pulley off from the outside, the hubs weren't too bad?
pfrederi
Your brake with a round shaft and keyway "should" have had a snap ring. Looks like it is gone can you see the groove on the shaft it would have been in???
Psychonova68
I took it off, didn't realize that's all that holds it on. On another note I realized that the tractor doesn't say commando 8 anywhere on it, but that's what it was advertised as and that's what the owners manual that I have says. Hood says wheel horse six speed and it does have a plate that looks original that shows high and low in front of the shifters. Serial number plate says model # T 867 and serial#367714. So any idea what model this is?
ebinmaine
11 minutes ago, Psychonova68 said:
model # T 867
That's literally it right there.
You have a 1967 8 horse, 6-speed.
It's Trina's favorite tractor of our herd.
Arguably one of the absolute favorites of many people on this site.
If that transmission is original and it likely is, you should have a limited-slip rear differential.
pfrederi
You got yourself a nice one.
Psychonova68
This whole process ever since I started researching old tractors has been a great learning experience.
Psychonova68
The hi lo shift lever looks to be held on with a roll pin, any advice? I have had a lot of bad luck with roll pins with guns.
ebinmaine
Leave it set.
No need to remove it unless removing the specific gears it's attached to.
pfrederi
It is a roll pin.  a true roll pin punch is your best weapon....
Edited by pfrederi
Pullstart
Great work getting those what someone might call welds off!  Was the left or right axle sticking out past the hub?  I don’t believe it should be offset or stick out so far like that...  @stevasaurus are we to expect any issues in the diff?
stevasaurus
That roll pin should pop right out.  I think you have a 4 leaf clover in your pocket to get all that stuff off while I was reading this thread.  Make sure you have the shallow side (right side) down when you open up the case.  I use an old 1" wood chisel and a pry bar to separate the case.  Find the right space and tap the chisel.  You might want to file any burrs that are on the ends of the axles, brake and input shafts so the case can slip by the bearings.  Trust me, it does not take much to keep from lifting off the case half.  AAHH!!  That's right, you have a 4 leaf clover.   :occasion-xmas:
   Pullstart, I don't think I would expect any issues with that transmission.  I would be interested to know how the oil looked when drained though.
stevasaurus
While that #5091 thread will walk you through the process, this thread is the same as your transmission...#5060.  Be careful with the differential, you should have aluminum end plates on the differential.  :orcs-cheers:
Psychonova68
I got the transmission opened up and have starting taking the gears out. My question is how do I tell if the bearings are bad? I noticed one of the axle bearings is missing some needles so that'll definitely get replaced, but from the rough inspection I've done so far most of them look fine.
ebinmaine
Clean em up and do a basic eyeball inspection just like you did to the wheel bearing.
Should replace both.
Others will chime in. Maybe with actual specs.
:lol:
Give a list of needed parts when you can.
Psychonova68
Will do, thank you very much.
Psychonova68
How do the shift forks and associated gears come out? How does the detent ball plug come out, I think that's where my problem is.
Edited by Psychonova68
further thoughts after looking at schematic
ebinmaine
I can't remember if that was a well plug/freeze plug on mine or if they screwed out ...
Steve's videos may show it.
I can check in the shop later this morning.
Be VERY aware of the position of those during disassembly.
Those have been known to fly across the room and land in the most inconvenient non accessible place within a 40 mile radius.
:lol:
oliver2-44
If the shifter worked fine before you took it apart, and the rails aren't rusty, you might try cleaning up the shift forks and rails in place.   Getting the detent balls back in place on the rails can involve lots of frustration and losing the little balls (which you can get at the hardware store).
stevasaurus
You want Section III in this manual.  It does a nice job of explaining the process...
Psychonova68
I can't seem to shift either fork much, I can lift the R &1 fork a little, but I can't push the 2&3 fork down to put it in neutral and start pulling the forks out. 1 of the detents on the R&1 fork should be engaged, but I don't see what's keeping me from pulling it out. Any ideas?
ebinmaine
I didn't get it looking how the detent balls come out the end.
Were you able to find them?
Psychonova68
I got it, I didn't realize I had to allow the shaft, I think it's the input shaft to go down. When I picked the case up and repositioned it, it allowed me to shift it into neutral and pull the forks out. The BBs just fell into the grease pool in the bottom, made sure to have my finger over the hole so they couldn't fly out. Just have to clean all the old oil out and inspect it now.
Psychonova68
Is there any way I can test the limited slip differential without disassembling it?
ebinmaine
@stevasaurus @pfrederi @Racinbob @953 nut
Good question for one the more experienced.
