Marc M. 12 #1 Posted February 3, 2020 Hello everyone I am having a hard time finding a few parts for my mower deck. The blades are 16in long with a 3/4 center hole that's about all i know. I am looking for the side pully and spindle .My pullys are not keyed. As you can see in my photos why I need a new one! Used three jaw puller. Torch Puller and hammer attack at the same time Cut off wheel Pipe wrench in vise. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,161 #2 Posted February 3, 2020 May help you identify the deck model Note - 3/4" or .750" is 19.05mm 1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole) - Originally had a nylon-insert nut holding spindle pulley on. 1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. Note - 17mm is .669" 1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1993-1997 model 78360 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. 1998-2007 and 2009-2012 model 78361 - Uses 6203 bearings with 17mm ID - (These all use blades with 3/4" center hole) - Originally had a standard nut and lockwasher holding spindle pulley on. Garry Share this post Link to post Share on other sites
Skwerl58 737 #3 Posted February 3, 2020 Look under the for sale section here. Also I found a new spindle on Amazon last year. Lots of Wheel Horse decks used the same spindles. 1 Share this post Link to post Share on other sites
Lee1977 6,898 #4 Posted February 8, 2020 That's a metric spindle the bearings are 6203 ( id 17 mm od 40 mm and 12mm wide ) the top of the spindle is 5/8". There is a good set of blades on Ebay ( Pro Parts Place ) 3 USA XTH Blades Toro 48" cut. for $38.99. They are the toughest blade I have ever used on my Wheel Horse. I 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #5 Posted February 8, 2020 Be real careful with the threads on these spindles cause they will damage very easily. Share this post Link to post Share on other sites
