troutbum70
New to me electro 12 not doing so well
JoeM
On 2/1/2020 at 6:36 AM, 953 nut said:
A set of Acceleration Valve Springs will probably make a BIG difference
953, school me on your thoughts of needing AVS's. Are they too stiff and not enough slip? Just curious,
thanks,
Joe
pfrederi
My thoughts
#1 Both Wheel-a -matic and hydro gear diagnostic charts point to Acceleration valves as potential problems in loss of power situations.
# 2 Failure to seat properly is going to bleed off pressure
#3 Mangled acceleration valve springs are all too common (so much so that Lowell is working on getting them reproduced.)
Edited by pfrederi
JoeM
I could see if the hydro was loosing power but I think he is talking about the engine losing power.
I got the hydro thing figured out, just thought there was something different.
thanks
oliver2-44
On 2/1/2020 at 10:25 PM, troutbum63 said:
Okay and I don't have a leak down tester, so will do old fashioned way. By applying 30 or40 lbs of air at tdc and listen at exhaust, carb with throttle open, and oil fill tube for any air leaking by. Or hold a feather at those points to see any air leaking by.
When you do a leak down test, I’ve learned it’s best to run the engine to warm it up to operating temperature. That way everything has expanded and tightened to normal operation. A cold leak down test can give false information
oliver2-44
953 nut
thanks
A hydro with compromised acceleration springs will allow the forward and reverse valves to remain partially open at the same time. This will result as sluggish operation.
troutbum70
Oliver that is probably a very good point. Am going to do cold first and then warm it up good and test again. Stand by for results.
