pfrederi 18,267 #1 Posted October 4, 2018 (edited) O rings are described by a dash number as well as dimensions. A good auto parts store or hardware source should understand dash numbers Here are some replacement numbers for O rings WH used on Sundstrand hydros D Series Manifolds Small WH# 971015 Dash # 015 Large WH# 971018 Dash # 018 Backer ring WH# 103184 Dash #018BU Charger Electro and Early C Series Motion Control Large WH# 970026 Dash # 026 (I use the square version seems to seal better and is easier to install # 026S) Small WH# 972116 Dash #116 Tow Valve WH# 971113 Dash # 113 (Uses 2) (Under seat with a roll pin for a handle) There is also a backer ring WH#7268 it is a PTFE (plastic) ring dash #113. I have not replaced any on mine but the McMaster picture below should be what you need If you have a newer C series with tow valve on the side under the fender the valve uses WH# 971012 based on WH #system I would guess it is Dash #012 The ports on the hydro cylinders control valve and pump are either SAE ORB #5 or #6 They have an O ring The #5 (smaller 1/2 -20 threads)) use dash #905 the #6 use dash #906 ( 9/16 18 tpi thread) WH # for ORB5 ring is 973310 for the ORB 6 WH# 973370 Another note, O rings I get have a shelf life of 15 years. Long time ...but some of the NOS WH parts are getting pretty old. I have extras of most all of them...if you need some just PM me (They work out to 5-10 cents apiece) Input shaft seal for D series and Charger early C series WH # 7877 is CR 7475 (I guess it is SKF now..I am old school.) One other item the woodruff key in the motion control linkage WH #937007 1/8 x 1/2 is also known as #3 woodruff key Sealing washer used on D series hydro motor in picture PTFE Backer ring for tow valve Edited October 29, 2018 by pfrederi 5 3 Share this post Link to post Share on other sites
Sarge 3,464 #2 Posted October 7, 2018 Excellent info Paul, we need a lot more stuff like this to help others clarify the parts on not only the D series, but all of the machines with Sundstrand units. These systems were built 40 miles from where I lived, sure wish years ago I had enough forethought to go speak with their engineers and try to learn more from them as well as inquire about any manuals. They are still in business and producing many of the parts we need, sources like LJ Fluid Power in Michigan are a goldmine of knowledge and keep most of what is needed in stock. McMaster-Carr has been my source for a lot of odd hardware, materials, and parts for years. If I order before 6pm, parts are here the next morning out of Chicago's warehouse, awesome. Sarge 1 Share this post Link to post Share on other sites
pfrederi 18,267 #3 Posted January 31, 2020 If anyone is into their hydro gear this picture may help ID the O rings you are looking for. The penciled in #s are standard O ring Dash #s. Two other numbers I have are for the charge pump (not shown) are 2 large ones #021S and 4 small ones #011S. I have all these rings (When you buy them in bulk from McMaster they are only a few cent each) so if you need some PM me I will mail you some. 1 2 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #4 Posted January 31, 2020 I did call LJ fluid power and they have the whole kit for around 45. Im assuming that included the seals needed. Share this post Link to post Share on other sites
pfrederi 18,267 #5 Posted January 31, 2020 26 minutes ago, The Tool Crib said: I did call LJ fluid power and they have the whole kit for around 45. Im assuming that included the seals needed. Be interesting to know what is n the i"kit" Share this post Link to post Share on other sites
The Tuul Crib 7,338 #6 Posted January 31, 2020 What are the seals that are needed for the 2046 beside the O-rings? Share this post Link to post Share on other sites
pfrederi 18,267 #7 Posted January 31, 2020 9 minutes ago, The Tool Crib said: What are the seals that are needed for the 2046 beside the O-rings? CR7475 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #8 Posted January 31, 2020 6 minutes ago, pfrederi said: CR7475 Just one seal is always needed? Share this post Link to post Share on other sites
pfrederi 18,267 #9 Posted January 31, 2020 2 minutes ago, The Tool Crib said: Just one seal is always needed? Yep!! later Piston to piston units used 3 seals input shaft (1) and swash plate pivot shaft (2) instead of the O rings used in 2046. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #10 Posted January 31, 2020 Just now, pfrederi said: Yep!! later Piston to piston units used 3 seals input shaft (1) and swash plate pivot shaft (2) instead of the O rings used in 2046. Ok to send you a pm? Share this post Link to post Share on other sites
pfrederi 18,267 #11 Posted January 31, 2020 1 minute ago, The Tool Crib said: Ok to send you a pm? yes Share this post Link to post Share on other sites
daveoman1966 3,787 #12 Posted January 31, 2020 This is the list from L J Fluid Power... Share this post Link to post Share on other sites
Richard England 1 #13 Posted December 22, 2020 pfrederi, Thanks for the dash numbers. As the WH part numbers become harder to find, the alternative commodity information is very valuable. 1 Share this post Link to post Share on other sites
ebinmaine 70,207 #14 Posted January 21, 2023 Excellent information here Paul. Share this post Link to post Share on other sites
ebinmaine 70,207 #15 Posted January 21, 2023 On 1/31/2020 at 2:51 PM, pfrederi said: CR7475 To add an update to the above number, here's a post from my 1975 C160 Automatic restoration thread. I got new information from a friend at the parts store for a usable replacement seal. National 480821. Share this post Link to post Share on other sites
pfrederi 18,267 #16 Posted January 21, 2023 9 minutes ago, ebinmaine said: To add an update to the above number, here's a post from my 1975 C160 Automatic restoration thread. I got new information from a friend at the parts store for a usable replacement seal. National 480821. That National number is equivalent to SKF 7474, a single lip seal. i prefer the SKF 7475 as it is a double lip seal, helps keep the dirt out. 1 Share this post Link to post Share on other sites
peter lena 9,048 #17 Posted January 21, 2023 @pfrederi help prevent seal twist / seating , https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae-51004/i/G5124506/? mad e for that set up . endless uses on a horse . pete Share this post Link to post Share on other sites
gt14rider 821 #18 Posted January 24, 2023 Here's what I have on 1 Share this post Link to post Share on other sites
