huey
c-141 hydro
huey
c-141 hydro quit on me and i can't push it I turned valve under seat but still won't disengage transmission, what should i do?
pfrederi
Try jacking it up and then try to turn the wheels. it may be that a differential bolt broke and has gotten wedged between the bull gear and the trans axle case.  Wiggle wheels back and forth it may push the offending broken whatever clear of the bull gear .  Don't try dragging it  there is the chance of breaking the transaxle housing.
daveoman1966
With the 'push' valve open, the tractor should be pushed...VERY SLOWLY... much less than a walking pace.
As pfrederi says...may also be a broken diff bolt.
  • Like 4
huey
I've tried to move it but no luck, when i jack up the back end  and turn one wheel forward the other goes in reverse, the hydraulic lift still works and when i move the motion control lever forward it seems to be under load. Just wondering how hard is it to take trans apart?
The Tuul Crib
:text-welcomeconfetti:to:rs:huey!
:wwp:. Im learning about these
hydros as well. Im used to 4 and 8 speeds!
Edited by The Tool Crib
