huey 7 #1 Posted January 26, 2020 c-141 hydro quit on me and i can't push it I turned valve under seat but still won't disengage transmission, what should i do? Share this post Link to post Share on other sites
pfrederi 19,241 #2 Posted January 26, 2020 Try jacking it up and then try to turn the wheels. it may be that a differential bolt broke and has gotten wedged between the bull gear and the trans axle case. Wiggle wheels back and forth it may push the offending broken whatever clear of the bull gear . Don't try dragging it there is the chance of breaking the transaxle housing. 2 Share this post Link to post Share on other sites
daveoman1966 3,880 #3 Posted January 26, 2020 With the 'push' valve open, the tractor should be pushed...VERY SLOWLY... much less than a walking pace. As pfrederi says...may also be a broken diff bolt. 4 Share this post Link to post Share on other sites
huey 7 #4 Posted February 1, 2020 I've tried to move it but no luck, when i jack up the back end and turn one wheel forward the other goes in reverse, the hydraulic lift still works and when i move the motion control lever forward it seems to be under load. Just wondering how hard is it to take trans apart? Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted February 2, 2020 (edited) tohuey! . Im learning about these hydros as well. Im used to 4 and 8 speeds! Edited February 2, 2020 by The Tool Crib 2 Share this post Link to post Share on other sites
