Similar Content
By Gravely Horse
I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
By bigbuck
I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
please call George at 517-499-5678 for more info.
By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
By CasualObserver
Owners manual for the Single cylinder snowmobile engines.
12 pages 1.33MB
1970 295 Safari snowmobile model 9-0011 - 1-cylinder
1970 309 Safari snowmobile model 9-0021 - 1-cylinder
1970 309W Safari snowmobile model 9-0061 - 1-cylinder
1970 355 Safari snowmobile model 9-0031 - 1-cylinder
1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
By Metal Blender
My 312 hydro has the 12hp kohler motor,It has 3 wires white,purple and orange coming out from the stator area but the orange is not hooked up.The stator test around 40 volts ( multimeter test) but the battery is not charging.The regulator is cheap but new (not OEM).My question is the orange wire,what is it for? If I should hook it up? If yes then to what should it be run to?Battery +?. My regulator test was a failure but the tractor runs fine besides de-charging.Im searching for alternative reasons for the regulator not working other than its no good.Like cleaning and refitting all ground connections,cleaning and refitting the battery terminals and connecting wires.Is it posable the ignition switch is the wrong one or is failing at one or more poles? Thanks for any help
