Mudrig150
REVOLT tractors
Mudrig150
Here's my thread for all the Revolt tractor designs I make. These are all original designs, made by me.
Here's the F-1925, part of the Revolt F-series, which was produced from 1963-1974. It features a water cooled 6 cylinder diesel, which produces 125 horsepower, and is hooked to a Dual range hydrostatic transmission. It puts out 94 horsepower at the drawbar and 106 at the PTO. It has a top speed of 19 MPH (full throttle, full forward on hydro, high range). Its equipped with 4WD.
Second picture is the tractor in the prototype "White stripe" FA1925 color scheme.
Edited by Mudrig150
  • Like 5
Pullstart
Your CAD skills are pretty awesome!  It will be awesome when you put your skills to work and build yourself a cool little nest egg for your future!
Mudrig150
Also made these. Revolt Vegus (pronounced like Las Vegas), it has a ton of cool features, is powered by a Boxer 6, and is loosely based off a volkswagen jetta.
Mudrig150
The F-1925 series 2 hood, it's a mix of Gravely, Cub cadet, and Bolens styling.
Mudrig150
I'm taking design suggestions for the next model... What design features should I put in the FA15, 17, and 19? They are all series so they will be similar. 1951-1963, so keep it in that time range.
Mudrig150
Now to design the GT-166. It's going to be based off the WH GT14.
Mudrig150
Done with the FA19. Started making a Garden tractor, the LG-166.
Revolt FA19
Engine HP 5
No. of Cylinders 3
Bore X Stroke 6 x 9 Inches
Maximum Operating RPM 850
Dry Weight 5,167 Pounds
Fuel Capacity 37.4 Gallons
Top Speed 2 MPH (Gear 1) 5 MPH (Gear 2) 10 MPH (Gear 3) -2 MPH (Reverse)
Maximum drawbar pull* 10,561 Pounds
3 point hitch Category 1
Rear PTO 540 RPM
*Gear 1, 700 RPM with 5,000 lbs of ballast
