Prater 76 #1 Posted April 26, 2009 Went over to pick up a 16hp block and ended up comng home with this engine from a Wheel Horse. The PO said it was an old 50's or 60's Horse that it was pulled from but did not know if it was original. The serial number indicates an 80's engine, Any idea? Serial number is 10049789 and the bottom plate seems to be fro part of the frame. Ended up wit a Kohler verticle shaft also if anyone is interested. Share this post Link to post Share on other sites
WHC-125 4 #2 Posted April 26, 2009 I wish you were closer because that 10 hp would be good in my C-160 Share this post Link to post Share on other sites
Duff 206 #3 Posted April 26, 2009 Steven, I'm going to take a SWAG (scientific wild azz guess) that bottom plate may be part of what I've heard the guys here call a "shaker mount." Don't know anything about 'em, but I've seen the term pop up here from time to time and it looks like some rubber bushings around the mounting bolts. Experts? Duff :omg: Share this post Link to post Share on other sites
JimD 3,345 #4 Posted April 26, 2009 my c85 has that mount. Share this post Link to post Share on other sites
WH854 44 #5 Posted April 27, 2009 That is Called Engine Cradle here it is. IF that was not on your tractor it would rattle your teeth, also your PTO hoop fits in a hole on the side. Actually it is a moter mount like in cars and trucks. Chas :omg: Share this post Link to post Share on other sites
clintonnut 126 #6 Posted April 27, 2009 Hi Looks like a K241AQS. Due to the base plate. There is a model number cast into the block 2 inches above the crankshaft on the PTO side. Charlie Share this post Link to post Share on other sites
WH854 44 #7 Posted April 27, 2009 I have a K241S the Number on the side of block stamped K301. Brian Miller says the blocks with that stamped on them can be used for 10,12,14 HP.Ijust read it on his site. Chas. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #8 Posted April 27, 2009 I just had time to look at this post and even though the decal is missing, I'd say this engine is a K241AS-46805D from a 1980 C-105. It's black, mounted on an isolation cradle, has a 10hp decal, and the serial number denotes 1980. (early) Chas is correct on the K"xxx" numbers that are sometimes cast into the PTO side.... they don't always mean what they say. :omg: Share this post Link to post Share on other sites
