Denis L Goulet 17 #1 Posted January 13, 2020 hi, again I have to replace nylon tension block on 1996 snow thrower 79361. anybody know simplest way of doing it, can I go underneath the blower and remove screws and take it out and put in the new one or its not that simple.thanks. Share this post Link to post Share on other sites
lynnmor 7,302 #2 Posted January 13, 2020 (edited) 9 hours ago, Denis L Goulet said: hi, again I have to replace nylon tension block on 1996 snow thrower 79361. anybody know simplest way of doing it, can I go underneath the blower and remove screws and take it out and put in the new one or its not that simple.thanks. Remove the guard by loosening two bolts. Remove the assembly bolts working from the top, it is extremely simple, but messy if the chain and bearing had proper lubrication. Edited January 14, 2020 by lynnmor Share this post Link to post Share on other sites
Denis L Goulet 17 #3 Posted January 13, 2020 ok, thanks for info, I wanted to check first, so far everything I do on this tractor is not easy, no space to work at all. Share this post Link to post Share on other sites
JCM 9,130 #4 Posted January 13, 2020 @Denis L Goulet Curious to find out what model tractor you own and also what are you finding difficult to work on, Share this post Link to post Share on other sites
Denis L Goulet 17 #5 Posted January 14, 2020 1996 520h, series 690......,with 79361 2 stage 44 inch blower, I had the 3 bearings changed on blower in November by the dealer, when it came back I used twice, the third time the chain broke. I phoned the dealer, he said he did not do work on the chain he was not responsible. I tried to install number 40 masterlink,that did not work it broke again so I looked further I noticed the tension block was worn out, and chain was rubbing on steel bracket, that's probably why it broke so I ordered a new chain, and block. now, I am looking in the 4 inch opening on top there's now way I can remove the block bolts there's no room to take them out.I cant remove the top idler sprocket with out removing the pto assembly. I am wondering, by removing the tension block bracket ,the bracket and tension block should come out the bottom. Share this post Link to post Share on other sites
