Herder 2,354 #1 Posted January 12, 2020 Most of us have some type of bearing/pulley puller in our shop. The down side is that most of them will only work on a bearing or pulley that is about 4-5/8 and smaller. I have few different types that I have purchased over the years. Recently I was trying to find one for larger pulleys because as you may know most pulleys on garden tractor are 4-5/8 and larger. Well this was no easy task. Not many available and the ones that are, are expensive. And then I found this!!! Pulls 5 to 7" pulleys. AutoZone (online) Was a bit pricey, $100.00-free shipping and the wife went online before placing the order and found a coupon code for an extra $20.00 off. About 85 bucks to the door. Fairly heavy and well built. Worked like a dream. This pulley was on pretty tight and came off without any damage. POP. Next. Couldn't be happier. So easy. I may make a set of flat half moon wedges to go between the jaws and the outer edge of the pulley for lightweight meatal pulleys to keep them from bending. 8 Share this post Link to post Share on other sites
ebinmaine 70,330 #2 Posted January 12, 2020 Nice!! A quality tool yet frugal. Well done herder and Mrs herder. 1 Share this post Link to post Share on other sites
Herder 2,354 #3 Posted January 12, 2020 1 minute ago, ebinmaine said: Nice!! A quality tool yet frugal. Well done herder and Mrs herder. Figured I would share the wealth. 1 1 Share this post Link to post Share on other sites
pacer 3,175 #4 Posted January 13, 2020 I have not seen that type puller ----- and I LIKE IT!! True to yer name , you 'herded' that right up into the corral 1 Share this post Link to post Share on other sites
