Oldskool
Newb to the group
ebinmaine
  On 1/21/2020 at 2:59 PM, Oldskool said:
Hope I'm not wearing out my welcome with all the piddly questions
There's absolutely no such thing as that so please keep asking
To the best of my knowledge,  lead additive is not necessary in any Wheelhorse engine but I would love to hear corrections if anybody knows different.
There's been many discussions on oil types and brands.
General consensus seems to be straight 30 WITH detergent per Kohler manual.
Not sure about the brand. Others can help there.
stevasaurus
@Oldskool  I wanted to correct my memory when talking about your stepfather.  Suds was not his nickname...that belonged to another civilian employee named Sunderledge.  I also managed to find a couple of pictures of the group that went out on John's boat for Cod fish.  That is Butch Brisina in the red shirt.  He and John became good friends back then.
  • Excellent 2
Oldskool
@stevasaurus I thought the nickname didn't sound familiar. Thanks for posting the pics. Looks like it could be the Milbridge bay area in the background.
Oldskool
I have done some looking on here and then on the tractor. It seems to me there isn't a date code on the transmission. So how do you tell when it was made?
wallfish
Early model RJ-58s did not have cast codes on the trans. It would be on the top near the shifter.
Very early production had round rear hubs with 3 lug holes instead of the typical 3 hole with ear hubs.
Very very early also used a leather shift boot instead of the rubber ones
Oldskool
I looked by the shifter and no casting numbers there. The I.D. tag has 1757 stamped on it but that is all I can read
Edited by Oldskool
wallfish
Considering there were about 20,000 made, I'd say you have an earlier production since 1757 is the serial # and therefore no cast #. I have no idea when the cast numbers started.
Oldskool
Had some spare time before supper so I thought I would make a hitch for the tractor. What good is a tractor without a hitch right?
Oldskool
I was lucky enough to find a vintage trailer ball and it was  1 7/8. Matches all our trailer couplers
Oldskool
ebinmaine
Nice work there mr skool
wallfish
Does that tractor have a belt guard for the drive belt?
Oldskool
Thank you.@ebinmaine
Oldskool
@wallfish Yes it does have a belt guard
wallfish
I just went back and looked at the pics. Duh
Only asked because I have a pattern you could use to make one
Oldskool
Thanks for the offer @wallfish. Looks like those fenders are coming home this weekend.
Oldskool
Home early today. I was thinking I might pull the steering wheel off for some repairs. Ya that isn't coming off without a fight.  I have it braced off. I drilled all the rust out from inside the roll pin. Sprayed PB Blaster inside the pin. I made a small extension to go over my roll pin punch to get out beyond the outside of the wheel to make it easier to hit. Any tips/shortcuts?
ebinmaine
I'll let the other guys help out with advice to remove it. I've not tackled a steering wheel yet.
they are certainly well known to be the bane of existence of a horse owner in the same manner as a hub.
Lots of us have our favorite brews for penetrating oil.
My favorite is probably the old school inexpensive liquid wrench penetrating oil. Like $6 a can and works pretty well.
Not so favorite would be PB blaster.
I just really haven't had any luck with that stuff at all and it smells worse than I look.
Patience. That is a key element.
Oldskool
@ebinmaine my hubs just slid rite off so wouldn't ya know it, the steering wheel will be the worst. I'm a big fan of WD-40 myself but I ran out. Sometimes patience isn't my best friend lol
ebinmaine
  On 1/24/2020 at 9:13 PM, Oldskool said:
WD-40
Find the one that reads
WD 40 Penetrant Or Penetrating
That stuff's excellent....
wallfish
Found the box. If this doesn't work, I can just send you the box and you can send it back.
The measurements were taken from the inside so it can be laid out on the flat piece and marked for bending.
wallfish
wallfish
  • Excellent 2
SylvanLakeWH
I ended up drilling mine out. Small bit to larger....patient, repetitive, two broken bits... then success...
:twocents-02cents:
