Mudrig150
John deere 200 series hydro
Mudrig150
I was planning on a simple build... A John deere 200 series with a WH hydro trans in it. Variator delete, maybe.
Hm... Maybe someday.
bds1984
What Wheel Horse transmission and which 200 series JD?
T-Mo
If adjusted correctly, the variator on the Peerless 2300 transmissions are great - gives you different speeds in 4 different gears going forward.  To be honest, if you want a John Deere hydro, stay with your 140 or your 317.  I don't see any benefit of putting a hydro in a 200 series.
Mudrig150
Cool value.
T-Mo
Reminds me of a guy I know - who started a lot of "cool" projects.  He got them to a certain point, then quit as he started another "cool" project.  The point is, you seem to have a lot of projects either started or in the planning stages.  It would be better to stay focus on a certain project, time and money wise, and get it finished before moving on to the next project.
As for the cool value of a hydro 200 series, the frames on a John Deere 200 series are wider than the frame of a Wheel Horse.  So there may have to be some brackets made to fit a hydro from a WH on a 200 series JD.  Also, pulleys probably won't align properly due to the differences in frame widths.  I've seen a lot of "cool" 200 series JDs, but every one of them took prior planning, a big wallet, a lot of time, a lot of fabrication, and a lot of headaches.  Do your self a favor and put this one on the back burner and finished the ones you already started.
Mudrig150
That's the plan. It's just an idea.
Herder
:text-yeahthat:Multiple belts and pulleys, adjustments and nun if it is easy to get too!!  This ones has been a challenge since it showed up.  She wants to stay retired.
