ebinmaine 67,611 #76 Posted April 30, 2020 2 minutes ago, chip61 said: daily driver Like that ole Dodge... 1 Share this post Link to post Share on other sites
Zeek 2,286 #77 Posted April 30, 2020 (edited) I've always had trucks too. Theses are two of the first of six Fords I had over the years: This was a 78 Ford 150, 351, auto. Was brown and tan originally. I worked at a body shop at the time so I replaced the bed and repainted it. I forget what year this truck was. It was a straight six, four speed Edited April 30, 2020 by Zeek 8 1 2 Share this post Link to post Share on other sites
chip61 658 #78 Posted April 30, 2020 39 minutes ago, ebinmaine said: Like that ole Dodge... Thanks-I've really enjoyed it, but I wish it rode better. I would say it rides like a bobtail tractor, but it doesn't ride that good LOL. It needs at least 1,000 lbs in the bed to ride decent. 1 Share this post Link to post Share on other sites
EricF 589 #79 Posted April 30, 2020 55 minutes ago, Zeek said: I forget what year this truck was. It was a straight six, four speed Looks like an 83/84 or maybe later. 83 I think was when they started putting the blue oval in the grille. Prior years in that body style still had "FORD" spelled out in chrome block letters on the edge of the hood. I had an 83 -- my first truck. Bare-bones base 2wd model with the straight six and the 3-on-the-tree, but the pervious owner had special-ordered it with beefed-up rear springs and a heavy-duty clutch. Basically, a "heavy half" (which is what the F150 originally was) upgraded to a 3/4-ton in everything but the official legal specs. Rumor was that configuration was how the Michigan DOT specced their F150s at the time, and this one was either tacked onto an order, or the dealer knew how to enter it. Heavy hauling capacity at a bargain price. The previous owner used it as a hauler for a machine shop; it had forklift dents in the rear fender wells from loading stuff. The old 300 straight six was kind of an "honorary diesel" -- gobs of low-end torque and economical on fuel if you kept your foot out of it on the highway. And it could still haul heavy stuff with a 3:73 highway rear end -- 4:10s not needed, even with the 3-speed -- which meant it could whip along in freeway traffic without running out of get-up-and-go, so long as it wasn't over-loaded. Getting clutch work done on that particular truck was always a pain in the neck. When they opened it up, what was inside didn't match the parts fiche! The last time it had work done, the shop said "Don't bring it back because that clutch doesn't belong in there!" 3 Share this post Link to post Share on other sites
1995 520H+96+97 937 #80 Posted April 30, 2020 @chip61 To make that ride awesome, jack up the frame, or if you have a lift, spray fluid film between the spring leaves. Doing the front and rear springs for that rig. 1 Share this post Link to post Share on other sites
chip61 658 #81 Posted May 1, 2020 Good idea-I keep talking about removing the rear spring packs and having a spring shop install teflon tabs on the ends, but I never get around to it. The fluid film is a quick and simple solution. I also think removing a leaf from the rear spring packs would help. Thanks! 1 Share this post Link to post Share on other sites
1995 520H+96+97 937 #82 Posted May 1, 2020 Quick, easy, cheaper. 35 PSI rear, 45 PSI front empty. 55 PSI rear, 45 PSI front loaded. Hammerdown, get that suspension and cummins smiling. 1 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #83 Posted May 1, 2020 These are my two, work van 99 ,240,000 and 2002 excursion 104,000 both with 7.3 diesels 3 1 Share this post Link to post Share on other sites
Pullstart 62,912 #84 Posted May 11, 2020 Check out this drain plug! 2 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #85 Posted May 11, 2020 So it's like a half turn quick release, is the pan metal or is it composite, good luck with your new ride Share this post Link to post Share on other sites
Tractorhead 9,064 #86 Posted May 11, 2020 Plastic oilpan huh, maybe it‘s a good idea to have a gravel protection for the Oilpan to cover. Share this post Link to post Share on other sites
8ntruck 7,016 #87 Posted May 22, 2020 I gave my 2015 Ram with a 5.7 Hemi a little exercise today. Dragged the pontoon out of storage. 4 Share this post Link to post Share on other sites
Pullstart 62,912 #88 Posted August 12, 2020 This one’s for all the hot rodder souls out there, wondering why in the world someone would want a 4 cylinder turbo in a truck... It’ll still light ‘em up... This might have happened a week or so ago. It could’ve kept on keepin’ on... the pedal got lightened up to regain traction but it kept wanting to break ‘em loose 2 1 4 Share this post Link to post Share on other sites
WHX?? 48,828 #89 Posted August 12, 2020 Dang Kids! 1 2 Share this post Link to post Share on other sites
tom2p 2,394 #90 Posted August 12, 2020 (edited) 11 hours ago, pullstart said: This one’s for all the hot rodder souls out there, wondering why in the world someone would want a 4 cylinder turbo in a truck... It’ll still light ‘em up... This might have happened a week or so ago. It could’ve kept on keepin’ on... the pedal got lightened up to regain traction but it kept wanting to break ‘em loose 1.5 liter 4 cyl turbo 1010 horsepower Edited August 12, 2020 by tom2p 1 Share this post Link to post Share on other sites
Redneckdavis 308 #91 Posted August 13, 2020 Those black squiggly things keep showing up at my house. I think it's a Ford thing:) 2 3 2 Share this post Link to post Share on other sites
WHX?? 48,828 #92 Posted August 13, 2020 @Achto has got ya all beat! 2 3 4 1 Share this post Link to post Share on other sites
Redneckdavis 308 #93 Posted August 13, 2020 One wheel wonder 1 1 Share this post Link to post Share on other sites
Pullstart 62,912 #94 Posted August 13, 2020 4 hours ago, Redneckdavis said: Those black squiggly things keep showing up at my house. I think it's a Ford thing:) Brakes locking up? You know where my loyalty stands, but that is a sharp ride there 1 4 Share this post Link to post Share on other sites
JCM 9,177 #95 Posted December 5, 2020 Found another pic of my 1999 classic Chevy K-2500 350 engine with 3.73 rear, average 13 mpg new in 99 up at camp. Real nice simple truck, a thing of the past unfortunately. 2 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #96 Posted December 6, 2020 (edited) Unfortunately I couldn't catch the culprit in the act could it have been this lil V6 wonder with the Caddy wheels or something with a bit bigger set of lungs... Edited December 6, 2020 by WVHillbilly520H 3 3 3 Share this post Link to post Share on other sites
ebinmaine 67,611 #97 Posted December 6, 2020 @WVHillbilly520H if you ever figure out who the rabble-rouser is that done that tell them I said "Nice work". 2 1 2 Share this post Link to post Share on other sites
Pullstart 62,912 #98 Posted December 6, 2020 (edited) Hey Jeff, you get that 4.3L running... then you can chase ‘em down! Edited December 6, 2020 by pullstart Auto correct Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #99 Posted December 6, 2020 12 minutes ago, pullstart said: Hey Jeff, you get that 4.3L running... then you can chase ‘em down! Yep... I guess I need to bite the bullet and send it to the "professionals" as the "shade tree" or lack there of isn't getting anywhere with it besides this. Share this post Link to post Share on other sites
