Mickwhitt 4,432 #1 Posted December 29, 2019 Hi all, Spent a productive day in the workshop making a couple of moustache combs! I have a plain plastic one and thought a nice nickel silver one might look good. I used to make miniature knives so a bit of that skill set came in handy. I used the horizontal mill to cut .030in slots 1.5mm apart. The top one has mother of pearl scales with gold pins. The bottom one is a straight comb for trimming the tash. Anyone else make odd items with their skills? Mick 2 11 Share this post Link to post Share on other sites
Stormin 9,980 #2 Posted December 29, 2019 Does a water feature count? Only thing I've got on tap. 3 12 Share this post Link to post Share on other sites
Mickwhitt 4,432 #3 Posted December 29, 2019 Nice one Norm. Only water feature we have is when rain pours down the hill I live on lol. Share this post Link to post Share on other sites
Pullstart 62,193 #4 Posted December 29, 2019 I put a tractor together one time, built a few pieces for it too. I guess you can call it odd 8 6 Share this post Link to post Share on other sites
diesel cowboy 263 #5 Posted December 29, 2019 I made a chess set at work for my niece for Christmas. Used old spark plugs for the pieces and wire ends to make the tops for the big ones and J.B. Weld epoxy to hold the washers to them for a base. Used a piece of scrap masonite for the board and tried to paint the squares but after 3 days of the paint not sticking to the primer coat I gave up and got a couple small sheets of pink and purple peel and stick felt and cut all the little squares out and stuck them down. 9 4 1 Share this post Link to post Share on other sites
Ed Kennell 37,491 #6 Posted December 29, 2019 Not mine, but John's toothpick should qualify. 13 Share this post Link to post Share on other sites
Stormin 9,980 #7 Posted December 29, 2019 (edited) Old bird bath stand and cast iron Bamfords seat. Edited December 29, 2019 by Stormin 8 2 Share this post Link to post Share on other sites
Digger 66 3,478 #8 Posted December 29, 2019 I made this > ( it's rather odd ) https://app.box.com/s/sw616xwg0y8i6eqrgy0kp2ncz1skwk7w 2 Share this post Link to post Share on other sites
tom2p 2,394 #9 Posted December 29, 2019 1 hour ago, pullstart said: I put a tractor together one time, built a few pieces for it too. I guess you can call it odd two thumbs up ! Share this post Link to post Share on other sites
tom2p 2,394 #10 Posted December 29, 2019 27 minutes ago, Digger 66 said: I made this > ( it's rather odd ) https://app.box.com/s/sw616xwg0y8i6eqrgy0kp2ncz1skwk7w rather good also - nice ! 1 Share this post Link to post Share on other sites
Digger 66 3,478 #11 Posted December 29, 2019 8 minutes ago, tom2p said: rather good also - nice ! Thank you , I did all but the vocal . Share this post Link to post Share on other sites
ebinmaine 66,581 #12 Posted December 29, 2019 This shoe shelf is one of the bajillion things Trina has done/built/made around here. 8 1 Share this post Link to post Share on other sites
ebinmaine 66,581 #13 Posted December 29, 2019 Also this table. Trina, her mom, and I were cutting firewood a few days ago and Trina and her mom both noticed the pretty grain on a particular piece of beechwood. I sliced off a piece about 2.5" to 3" thick and Trina made a table from it. @JCM you'd be proud of her .... The base is all copper pipes and fittings. ALL cut and fitted by her. Not soldered but friction fit holds it tight. The base (except the 90 elbows) is scrap from when we removed the oil system from the house. She even used recycled pipe hanger brackets from the house to hold the base to the wood top. The lower shelf is a few pieces of scrap shiplap pine cut to fit together. It acts as a point of support as well as a shelf. (That was an interesting experiment on the sliding compound miter saw. Neither of us had ever tried to join 3 things in a triangle like that. Internet search, cut some samples, learned a new skill....) She sanded the base and painted it Hammered Dark Bronze. Then sanded the top and put 3 or 4 coats of poly on the bottom, 5 or 6 on the topmost surface. Trina gave it as a "just because" gift to her Mama. 5 5 Share this post Link to post Share on other sites
tom2p 2,394 #14 Posted December 29, 2019 2 hours ago, Digger 66 said: Thank you , I did all but the vocal rhythm and lead ? drums / percussion also ? my youngest is into guitar ... acoustic and electric ... amps ... pedals ... etc Share this post Link to post Share on other sites
MikMacMike 479 #15 Posted December 29, 2019 39 minutes ago, ebinmaine said: Also this table. Trina, her mom, and I were cutting firewood a few days ago and Trina and her mom both noticed the pretty grain on a particular piece of beechwood. I sliced off a piece about 2.5" to 3" thick and Trina made a table from it. @JCM you'd be proud of her .... The base is all copper pipes and fittings. ALL cut and fitted by her. Not soldered but friction fit holds it tight. The base (except the 90 elbows) is scrap from when we removed the oil system from the house. She even used recycled pipe hanger brackets from the house to hold the base to the wood top. The lower shelf is a few pieces of scrap shiplap pine cut to fit together. It acts as a point of support as well as a shelf. (That was an interesting experiment on the sliding compound miter saw. Neither of us had ever tried to join 3 things in a triangle like that. Internet search, cut some samples, learned a new skill....) She sanded the base and painted it Hammered Dark Bronze. Then sanded the top and put 3 or 4 coats of poly on the bottom, 5 or 6 on the topmost surface. Trina gave it as a "just because" gift to her Mama. Plumbing fittings? Ebinmaine Trina and Maw kettle you didnt say you had plumber skills, What a what a gorgouse piece.....live edge wood made into anything is always so gorgouse too. Dont let yr local plumber see it, he will definately want it !!! 1 Share this post Link to post Share on other sites
MikMacMike 479 #16 Posted December 29, 2019 4 hours ago, Ed Kennell said: Not mine, but John's toothpick should qualify. Whuaaaaaa to say the least, such skill. Share this post Link to post Share on other sites
tom2p 2,394 #17 Posted December 29, 2019 nice tables by Trina ! 2 1 Share this post Link to post Share on other sites
JCM 9,062 #18 Posted December 30, 2019 @ebinmaine WOW that is NICE , The Table not your leg Please pass on the Congrats to the both of you. Super Cool . 1 1 Share this post Link to post Share on other sites
953 nut 54,374 #19 Posted December 30, 2019 I have made a couple of handy helpers for working on the . First is a dolley that can be used to remove and install a Wheel Horse transaxle without too much exertion. The other is a clamp that will hold a shift ball to be able to remove it without damaging the surface or hold it whill drilling and tapping new threads. 4 2 Share this post Link to post Share on other sites
MikMacMike 479 #20 Posted December 30, 2019 2 minutes ago, 953 nut said: I have made a couple of handy helpers for working on the . First is a dolley that can be used to remove and install a Wheel Horse transaxle without too much exertion. The other is a clamp that will hold a shift ball to be able to remove it without damaging the surface or hold it whill drilling and tapping new threads. wew going to copy that idea! Share this post Link to post Share on other sites
MikMacMike 479 #21 Posted December 30, 2019 7 minutes ago, JCM said: @ebinmaine WOW that is NICE , The Table not your leg Please pass on the Congrats to the both of you. Super Cool . I think Ebinmain uses neat hehehehe 3 Share this post Link to post Share on other sites
JCM 9,062 #22 Posted December 30, 2019 (edited) I was going with a similar comment then changed my mind, don't wan't to get the Bear angry. Edited December 30, 2019 by JCM 1 Share this post Link to post Share on other sites
MikMacMike 479 #23 Posted December 30, 2019 4 minutes ago, JCM said: I was going with a similar comment then changed my mind, don't won't to get the Bear angry. Oh? dang sorry.....I ment well plucked right...its more manly hehehehe......Im lucky right now theres a distance, Besides by the time I get to see you all Ill have definately calmed him down hehehehe. 1 Share this post Link to post Share on other sites
ebinmaine 66,581 #24 Posted December 30, 2019 6 minutes ago, JCM said: I was going with a similar comment then changed my mind, don't wan't to get the Bear angry. No worries there Jim. Takes a LOT to get this "Bear" angry. 1 Share this post Link to post Share on other sites
MikMacMike 479 #25 Posted December 30, 2019 1 minute ago, ebinmaine said: No worries there Jim. Takes a LOT to get this "Bear" angry. WEW good to know 1 Share this post Link to post Share on other sites
