rjashley 5 #1 Posted December 23, 2019 New to this forum. Loving it. Can any one tell me if attachments from a 1986 417-A will work an a 1989 416-8. Looking to get a package deal on a 417-A that comes with a plow,snowblower. Many thanks in advance. 1 Share this post Link to post Share on other sites
Stepney 2,325 #2 Posted December 23, 2019 Absolutely will, nearly the same tractor for all intents and purposes. 1 Share this post Link to post Share on other sites
rjashley 5 #4 Posted December 23, 2019 Awesome. I can't thank you enough. Share this post Link to post Share on other sites
rjashley 5 #5 Posted December 23, 2019 52 minutes ago, Stepney said: Absolutely will, nearly the same tractor for all intents and purposes. Many thanks Share this post Link to post Share on other sites
rjashley 5 #6 Posted December 23, 2019 28 minutes ago, ebinmaine said: Very helpful. Thanks Share this post Link to post Share on other sites
JCM 9,130 #7 Posted December 23, 2019 @rjashley to 417-A or 417-8 TOUGH tractor, go for it. Share this post Link to post Share on other sites
The Tuul Crib 7,336 #8 Posted December 23, 2019 Absolutely! All hook ups should be the same both long frames. to Share this post Link to post Share on other sites
rjashley 5 #9 Posted December 24, 2019 37 minutes ago, JCM said: @rjashley to 417-A or 417-8 TOUGH tractor, go for it. Thanks. I'll keep you posted. Share this post Link to post Share on other sites
rjashley 5 #10 Posted December 24, 2019 37 minutes ago, The Tool Crib said: Absolutely! All hook ups should be the same both long frames. to Thanks Share this post Link to post Share on other sites
JCM 9,130 #11 Posted December 24, 2019 Thank you, I have some recent pics of my 417-8 under the topic of Winter Trail Ride started by @Sparky back in February of this year under Wheelhorse Tractors, That Model will do anything you ask of it. Share this post Link to post Share on other sites
rjashley 5 #12 Posted December 24, 2019 3 minutes ago, JCM said: Thank you, I have some recent pics of my 417-8 under the topic of Winter Trail Ride started by @Sparky back in February of this year under Wheelhorse Tractors, That Model will do anything you ask of it. I was thinking of keeping the 416-8. Better engine and I like the two speed transmission. We'll see. 1 Share this post Link to post Share on other sites
rjashley 5 #13 Posted December 24, 2019 Thanks. Got some interesting comments. Which tractor do you think would be a better unit? Share this post Link to post Share on other sites
Stepney 2,325 #14 Posted December 24, 2019 Which is better for your application? This depends on what you want to do with it. For mowing and constant speed change and reverse work, nothing beats a hydro. However in this case, a 417-A. Someone more enlightened can shed some light but I believe the suffix A means auto trans manual lift. This would be the Eaton 7 transmission and it is a generally weak unit. Suffix H would mean auto drive and hydro lift. These units were much stronger. All that being said, the 416-8 is a gear drive with a 16hp kohler single, and that combination is tough as nails, just a little slower about doing it's thing. Share this post Link to post Share on other sites
c-series don 8,666 #15 Posted December 24, 2019 All the 417-A’s I’ve seen are hydraulic lift, I have one too! My 416-H is hydraulic lift as well. My 314-A is manual lift. The 518-H was manual lift, so I don’t think A or the H had anything to do with the lifting but I do think I’m more confused about this now than I was before!!!! 3 Share this post Link to post Share on other sites
ebinmaine 67,288 #16 Posted December 24, 2019 Uummmmm.... Keep em both ? 1 Share this post Link to post Share on other sites
JCM 9,130 #17 Posted December 24, 2019 Both 85 & 86 417-A were built with Eaton 1100 Hydro Trans with Hydraulic lift. The 416-8 depending on the year could have either a Kohler or Onan. 1985,6,7 and 8 the 416's were Kohler and 1989,90,91,92,93,94,95,96 and 97 were Onans. Hope I got that one right. 1 Share this post Link to post Share on other sites
rjashley 5 #18 Posted December 24, 2019 Mine is the 1989 with the onan engine 1 Share this post Link to post Share on other sites
Pullstart 62,799 #19 Posted December 24, 2019 @rjashley! I don’t have anything that new, but like to say 1 Share this post Link to post Share on other sites
MikMacMike 479 #20 Posted December 24, 2019 15 hours ago, Stepney said: Which is better for your application? This depends on what you want to do with it. For mowing and constant speed change and reverse work, nothing beats a hydro. However in this case, a 417-A. Someone more enlightened can shed some light but I believe the suffix A means auto trans manual lift. This would be the Eaton 7 transmission and it is a generally weak unit. Suffix H would mean auto drive and hydro lift. These units were much stronger. All that being said, the 416-8 is a gear drive with a 16hp kohler single, and that combination is tough as nails, just a little slower about doing it's thing. Stepney is absolutly right about the hydro being faster, in particulare where I noticed it had a seriouse advantage was if you are snow blowing and not turning around but backing up to take another swath, the speed also in very tight situations is like infinately variable too, I cant believe how slow you can go too, with out using any sort of clutch. I had no idea the eatons were weaker then the sunstrand....but that is very good info to know.....I used my sunstrand to pull 2800 lbs up to 4000 lbs cars around, although I did destroy the left rear axcel and hub, the key way blew a huge chunk right out. Its also good to know the 8 speeds are tough too, both sunstrand and the eight speed are on mine. 1 Share this post Link to post Share on other sites
tom2p 2,394 #21 Posted December 24, 2019 34 minutes ago, MikMacMike said: Stepney is absolutly right about the hydro being faster, in particulare where I noticed it had a seriouse advantage was if you are snow blowing and not turning around but backing up to take another swath, the speed also in very tight situations is like infinately variable too, I cant believe how slow you can go too, with out using any sort of clutch. I had no idea the eatons were weaker then the sunstrand....but that is very good info to know.....I used my sunstrand to pull 2800 lbs up to 4000 lbs cars around, although I did destroy the left rear axcel and hub, the key way blew a huge chunk right out. Its also good to know the 8 speeds are tough too, both sunstrand and the eight speed are on mine. The Eaton 1100's are very durable - but the 700's might not be as durable don't know how the Eaton 1100 compares to the Sundstrand 1 Share this post Link to post Share on other sites
tom2p 2,394 #22 Posted December 24, 2019 (edited) 8 hours ago, ebinmaine said: Uummmmm.... Keep em both ? agree and according to my therapist - the RedSquare group - it's better to keep both Edited December 24, 2019 by tom2p 3 1 Share this post Link to post Share on other sites
MikMacMike 479 #23 Posted December 24, 2019 Hmmm might be a good thing to research if someone was going to use the hydro for heavier pulling. I switch mine out to the 8 speed cuz I heard they were a little more bullit proof. I sure hope the sunstrand is the stronger one hahahaha I sure put mine through beasty pulls. 1 Share this post Link to post Share on other sites
pfrederi 17,672 #24 Posted December 24, 2019 I have several sunstrands and only 1 Eaton 1100. I would never posit that one was "stronger" than the other.. The Eatons are newer so maybe less wear and tear.... I think either one will work your limiting factor is always traction next weak link is probably the hubs/ keyways or the differential. Share this post Link to post Share on other sites
tom2p 2,394 #25 Posted December 24, 2019 (edited) 51 minutes ago, MikMacMike said: Stepney is absolutly right about the hydro being faster, in particulare where I noticed it had a seriouse advantage was if you are snow blowing and not turning around but backing up to take another swath, the speed also in very tight situations is like infinately variable too, I cant believe how slow you can go too, with out using any sort of clutch. I had no idea the eatons were weaker then the sunstrand....but that is very good info to know.....I used my sunstrand to pull 2800 lbs up to 4000 lbs cars around, although I did destroy the left rear axcel and hub, the key way blew a huge chunk right out. Its also good to know the 8 speeds are tough too, both sunstrand and the eight speed are on mine. agree - and can relate to tight situations and low speed with 416-H in some tight inclined areas it can be easier to navigate and if you lose traction - can then back off the lever just a tad to hold the tractor in place - and then can move forward slowly and power will then shift to both rear wheels ( hydro linkage needs to be adjusted properly to do this 'gracefully' with no jerking ) not able to do this with my 312-8 ... for sure not nearly as easily Edited December 24, 2019 by tom2p 1 Share this post Link to post Share on other sites
