Horse Play
Sealant for Fuel Line Fittings?
Horse Play
I am getting ready to assemble my RJ gas tank and sediment bowl along with the brass fittings.  Should I use a thread sealant on the NPT fittings?
Thank you!
gwest_ca
Yes
Garry
  • Like 4
JoeM
This stuff works pretty good, Rector Seal #5 available at Lowe's $6 ish. If you get some Knead the tube before opening to keep it mixed, sometime there is a slight separation.
RectorSeal No. 5 Pipe Thread Sealant (1-3/4 oz.) Product Image
RectorSeal No. 5 - RectorSeal.pdf
Edited by MrOiluj52
gwest_ca
Apply the sealer to the male threads only. That way none of it ends up in the system.
Garry
bottjernat1
I used gas line thread tape on my rj.
The Tuul Crib
Teflon tape
WHNJ701
1 hour ago, The Tool Crib said:
Teflon tape
i dont think its fuel safe???
I never sealed any of the threads on about 12 or so I own and don't have issues.  I don't keep much fuel in them and keep them dry in the winter
953 nut
Ultra Copper is the ony sealer I have ever used on fuel lines, others may work as well.
Image result for fuel safe thread sealant
ZXT
21 hours ago, The Tool Crib said:
Teflon tape
:text-yeahthat:
I don't typically use thread sealant on fuel fittings unless they leak, since pipe threads are designed to not leak in the first place. If they do, it's typically only a small drip, and I've used Teflon tape on tractors and cars with no issues.
I had a drip at the inlet of the sediment bowl on my dad's 57 Chevy when I put the 350 in it. I put Teflon on the threads to stop it. 8 years and about 10,000 miles later, still no drip.
Just make sure you wrap the tape in the right direction!
Edited by ZXT
Horse Play
Thank you, all very much!
rmaynard
I know I'm a little late to the party here, but if your fittings are the type with the rubber ring in them, you shouldn't need any sealant on the threads since the rubber is the seal, not the threads.  If they leak, replace the rubber seal.
As far as Teflon tape or Teflon paste, anything other than the yellow is not safe for fuel. Petroleum will dissolve it.
WildmanC120
Truth.  Use the yellow Teflon tape made for gas and you will be fine.  I use it all the time. You can even get it at Lowe's or Home Depot
