indywheelhorsenut
Snow coming c160 not starting.. lol. Of course
indywheelhorsenut
Started fine 2 weeks ago.  I left key in ignition and fear grandson may have turned it slightly to right a week ago.. not enough to engage starter but perhaps enough to drain battery.
Went to start it yesterday and no charge at all.  Started charging it and battery began to take charge.  However starter turned over but didnt turn engine over.
Question is do I just need more of a charge (more amps) or do I have another problem?
Lol, have 5 inches of snow headed here starting tonight so I need to get ahead of this today.
peter lena
sounds like a dead battery, with its very slow recovery, Walmart U1  battery's in the  300 + cca class for 30+ $ is the deal. i also have battery tenders on my battery's, hard wired the plug in from battery  lead, to my choke cable  , for simple easy access, pete
ebinmaine
Agreed.
Those batteries are more in the $40 range here in Maine but that's what I'd buy if in need.
Also check your spark plug and points to be sure they are still clean. Not corroded, pitted or otherwise.
I've heard of coils being damaged by leaving the key on.
Verify spark of some sort even if battery is weak.
indywheelhorsenut
Thanks guys.. I too feared it may have burned the points.. just hadn't gotten that far yet.
WVHillbilly520H
More details needed... Do you have the starter/generator or solid state style starter? You say starter turns over as in it is spinning but engine isn't spinning with starter or engine just isn't firing? Usually with low charged battery there's not enough current to spin the starter and fire the coil... Besides a battery tender ,a spark checker    https://www.harborfreight.com/90-In-Line-Spark-Checker-63593.html  is a cheap way to check for fire at the plug and this little gizmo will check the state of the battery and charging circuit https://www.harborfreight.com/12V-AlternatorBattery-Tester-63592.html
ZXT
Sounds to me like the battery has just enough to turn the starter motor over but not enough to kick it in to engage the flywheel.
Have you checked the water level in the battery? Leaving a key on will often times boil the water out of it. Might just need topped off with distilled water and then slow charged.
It is likely that it fried the points if they were open. If they weren't, you might be OK. The coil will probably be fine.
Edited by ZXT
indywheelhorsenut
Again.. many thanks!  It just fired up!!!!  Love my horse!  But will go by store and pick up some distilled water to top it off and put trickle on it just for good maintenance..
Bring on the snow!!!!!
  • Like 4
ZXT
What did you wind up having to do to it?
wfrpalm
Curious also.
Pullstart
IJonah he admitted there’s a problem, then it got better.  Like a noise in a customer’s vehicle!  :ROTF:
Edited by pullstart
Noise... not noose
  • Haha 2
indywheelhorsenut
Literally...  just allowing it to charge more solved the problem!  It was interesting as when the battery wasnt charged enough, the starter turned when I hit the ignition but it didnt turn over the engine.  Enough charge, starter worked as normal and engine cranked and started right up.
  • Excellent 1
  • Thanks 1
peter lena
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • MachXXII
      By MachXXII
      Does anyone know what battery a 1988 252-H needs. I looked around and couldn’t really find an answer. Thanks
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
