12Horse Paladin 1,038 #1 Posted December 6, 2019 (edited) Morning, everyone😊 I am going to be getting the tools needed (jack n jackstands n Valvoline 10w30 oil) today to change out the hydraulic fluid/filter on my Bronco 14, hoping to do this in the next few days b4 it turns cold.😁 Ive done searches n read my old manual n the lil bit of paper i have on it, but there isnt much of a description n no pics, on the procedure. I THINK I know which is the plug, but want to be sure. Could someone post a pic of where that drain plug is? Is there a procedure to follow, or tips or tricks? Or is it just like a car...pull the plug; the filter n drain, then replace all and that is it? Any and all pics would be very much appreciated! I'm assuming you just replace the fluid through the filler neck under the seat...i'm just praying that i pour slow enough, lol. Thanks for all your help n suggestions, everyone. Hope y'all have a good day! PS---Ithe expense wouldnt be a concern, rightnow....would it be best to change the fluid, run the tractor a bit, and change again, for any reason? I have limited space to actually move it around, but want to do this correctly/if necessary ...🤔 Edited December 6, 2019 by 12Horse Paladin 1 Share this post Link to post Share on other sites
ebinmaine 68,357 #2 Posted December 6, 2019 I don't have the answers for you because all of our tractors are gear drive but I'm curious to see what folks will say so I'm going to follow along.... 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #3 Posted December 6, 2019 What l have read here is to see what color the fluid that is in it . If its red go back with ATF and if it comes out a brown ish color then use motor oil . The drain plug is on the bottom . Lift the front up as high as you can to get all of the fluid out 1 Share this post Link to post Share on other sites
953 nut 55,778 #4 Posted December 6, 2019 The drain plug is on the bottom of the transmission near the trailer hitch, a 1/4" Allen wrench should fit it. Be sure to lift the front end up as high as you can to ensure complete draining. When it come time to fill the transmission a piece of wire between the side of the funnel and the fill tube will allow a small air space (vent path) to reduce the likelihood of fluid burping out. I don't think you would gain anything by changing the fluid twice. Chances are the fluid will look like new when it is drained. 3 1 Share this post Link to post Share on other sites
12Horse Paladin 1,038 #5 Posted December 6, 2019 Outside taking a look at things b4 i start, dunno if i will yet or not... Would anyone be able to provide a pic, roughly, of where thzt drain plug might be...? I see nothing on the bottom, as of yet, but do see 2 places that might b it, on the side of the case *shrugs* Thanks for any input on this, plus all so far! Share this post Link to post Share on other sites
The Tuul Crib 7,337 #6 Posted December 6, 2019 (edited) I don't have a picture but here is a breakdown of a parts list and its part number 47 it's under the hitch in the back. Edited December 6, 2019 by The Tool Crib Share this post Link to post Share on other sites
12Horse Paladin 1,038 #7 Posted December 6, 2019 12 minutes ago, The Tool Crib said: I don't have a picture but here is a breakdown of a parts list and its part number 47 it's under the hitch in the back. LOL! Sometimes i can b soooooo slow! Found it, thankyou!!!! 2 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #9 Posted December 6, 2019 1 hour ago, 12Horse Paladin said: LOL! Sometimes i can b soooooo slow! Found it, thankyou!!!! No worries ! That's what we're here for ! 1 Share this post Link to post Share on other sites
ZXT 2,401 #10 Posted December 7, 2019 16 hours ago, 953 nut said: When it come time to fill the transmission a piece of wire between the side of the funnel and the fill tube will allow a small air space (vent path) to reduce the likelihood of fluid burping out. Rest assured that if you don't have something allowing some air in while filling, you will have a nice sized mess to clean up! 1 Share this post Link to post Share on other sites
12Horse Paladin 1,038 #11 Posted December 7, 2019 7 hours ago, ZXT said: Rest assured that if you don't have something allowing some air in while filling, you will have a nice sized mess to clean up! I did see this bit of info elsewhere. Was planning on using a piece of wire... Thankyou! Share this post Link to post Share on other sites
pfrederi 17,879 #12 Posted December 7, 2019 2 hours ago, 12Horse Paladin said: I did see this bit of info elsewhere. Was planning on using a piece of wire... Thankyou! You will still have to pour very slowly to avoid burps.... Share this post Link to post Share on other sites
12Horse Paladin 1,038 #13 Posted December 8, 2019 21 hours ago, pfrederi said: You will still have to pour very slowly to avoid burps.... Believe it or not, i used a large plastic zip tie... And it was working GREAT...until the very last inch or so in the 5qt bottle (my fault)...think i tipped a lil too fast. I was awfully proud of m'self up to that point, having never done it before, lol. But now i bet i know why they put that one little hole under the seat, behind the filler neck😉🤔🤣 But, it is done😁 Fwiw...GLAD I DID...PO had used a 350 Chev Fram filter; PH16 I will never understand thinking like that....especially when you have a manual to reference (he did)....sigh.... Thanks for all your help, everyone! 2 1 Share this post Link to post Share on other sites
953 nut 55,778 #14 Posted December 8, 2019 7 hours ago, 12Horse Paladin said: PO had used a 350 Chev Fram filter; PH16 I guess he figured it looked the same and didn't know he need a hydraulic filter. 7 hours ago, 12Horse Paladin said: used a large plastic zip tie... And it was working GREAT...until the very last inch or so in the 5qt bottle I never had one need the full five quarts anyway! Share this post Link to post Share on other sites
12Horse Paladin 1,038 #15 Posted December 8, 2019 2 hours ago, 953 nut said: I guess he figured it looked the same and didn't know he need a hydraulic filter. I never had one need the full five quarts anyway! But, well.... If that is true, what happens if/when you overfill? The fluid now is so clear it is hard to read that dipstick; n i dont think i did, but shouldnt that be an exact/ universal amout, that the manual specifies? Share this post Link to post Share on other sites
pfrederi 17,879 #16 Posted December 8, 2019 All depends on how completely drained the system was.. Don't worry about it if there is fluid on your dipstick you are OK. if it is over full the worse that can happen is it may push some out the dipstick cap breather if it gets really hot. Look down the dipstick if the fluid is below the pipe do not worry. (if it is in the dipstick pipe suck some out.) Share this post Link to post Share on other sites
953 nut 55,778 #17 Posted December 9, 2019 2 hours ago, 12Horse Paladin said: The fluid now is so clear it is hard to read that dipstick If you pull the dipstick and lay it on a white rag or piece of paper the wet area will show up on the rag/paper. 1 Share this post Link to post Share on other sites
