sparkys toy 76 #1 Posted December 5, 2019 recently picked up a c-175 8 to mount a johnson loader i found on a charger with a broken frame and an auto transmission .only to discover the drive pulley was loose long enough to wear the case through the oil sealant to the bearing,rats what luck. later i found an raider 8 upon teardown found axle on drive side had two keyways,one halfround and the other straight both compleatly trashed,so my question is are the internal parts the same in both of these trannys ? the axle diameters are the same hopping to make one out of two,thanks for any help . Share this post Link to post Share on other sites
Darb1964 1,055 #2 Posted December 5, 2019 Not sure, but to do that damage someone must have abused the hell out of them tractors. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #3 Posted December 5, 2019 This should be the C-175 transmission. Click on the fuzzy pictures for more The Raider 8 model 1-0330 originally had a 5086 transmission which uses 1" diameter axles so must not be original A Raider 9 model 1-6931 used a 5060 transmission with 1-1/8" axles Garry 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #4 Posted December 5, 2019 (edited) @stevasaurus is our trans guru here . He has several videos in the trans section snd makes it look easy. to Edited December 5, 2019 by The Tool Crib Share this post Link to post Share on other sites
953 nut 55,773 #5 Posted December 5, 2019 If you have 1 1/8" axles on both transaxles you should be able to swap the entire differential and axles as a unit. The bonus would be that the Raider (5060) has a limited slip differential. Take a look at the Charger transaxle too, it has 1 1/8" axles and a limited slip rear. Share this post Link to post Share on other sites
The Tuul Crib 7,337 #6 Posted December 5, 2019 There are a lot of internal parts that did inner change, one I know that they put in every transmission was the cluster gear. They used the same gear on all of them. Share this post Link to post Share on other sites
sparkys toy 76 #7 Posted December 5, 2019 17 hours ago, Darb1964 said: Not sure, but to do that damage someone must have abused the hell out of them tractors. I was told it had a loader on it and I found the hub skrew loose and one of the two keys was gone and the half key almost sheared off 7 hours ago, The Tool Crib said: There are a lot of internal parts that did inner change, one I know that they put in every transmission was the cluster gear. They used the same gear on all of them. That's good I'm going to pull the 175 trans apart tonight and see what I can learn the first and reverse gear on the raider trans is worn almost to a point so I will need to replace it also Share this post Link to post Share on other sites
sparkys toy 76 #8 Posted December 5, 2019 8 hours ago, 953 nut said: If you have 1 1/8" axles on both transaxles you should be able to swap the entire differential and axles as a unit. The bonus would be that the Raider (5060) has a limited slip differential. Take a look at the Charger transaxle too, it has 1 1/8" axles and a limited slip rear. Sounds great I'm splitting the case on the 175 tonight and hopefully I can make a good one out of the two thanks guys,this Horse thing is getting to be an addiction 1 Share this post Link to post Share on other sites
953 nut 55,773 #9 Posted December 5, 2019 12 minutes ago, sparkys toy said: Horse thing is getting to be an addiction 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #10 Posted December 5, 2019 22 minutes ago, sparkys toy said: Sounds great I'm splitting the case on the 175 tonight and hopefully I can make a good one out of the two thanks guys,this Horse thing is getting to be an addiction Take lots of pictures as you're going that is very helpful . Share this post Link to post Share on other sites
sparkys toy 76 #11 Posted December 5, 2019 3 hours ago, sparkys toy said: Sounds great I'm splitting the case on the 175 tonight and hopefully I can make a good one out of the two thanks guys,this Horse thing is getting to be an addiction The one I have is a hydro Share this post Link to post Share on other sites
sparkys toy 76 #12 Posted December 5, 2019 3 hours ago, The Tool Crib said: Take lots of pictures as you're going that is very helpful . I always do ,my photograffic memory ran out of film years ago 1 Share this post Link to post Share on other sites
sparkys toy 76 #13 Posted December 6, 2019 (edited) 17 hours ago, The Tool Crib said: @stevasaurus is our trans guru here . He has several videos in the trans section snd makes it look easy. to thanks for the warm welcome cant wait to check out the vids Edited December 6, 2019 by sparkys toy Share this post Link to post Share on other sites
sparkys toy 76 #14 Posted December 6, 2019 13 hours ago, The Tool Crib said: @stevasaurus is our trans guru here . He has several videos in the trans section snd makes it look easy. to 14 minutes ago, sparkys toy said: You asked for it can't get pix to up load Share this post Link to post Share on other sites
The Tuul Crib 7,337 #15 Posted December 6, 2019 When you click on reply to topic at the bottom it will say click to choose files. Click on that and ad photos there. One word of advice if you become a member you have a unlimited photo up loads. Share this post Link to post Share on other sites
953 nut 55,773 #16 Posted December 6, 2019 To load a photo you need to download it to your computer, open a reply or edit, click on the choose files and your computer will go to your photo file, select the photo and it will be added to your post. Share this post Link to post Share on other sites
stevasaurus 22,865 #17 Posted December 6, 2019 I've been gone all week, but maybe I can help if you can post pics. I do have some questions to ask...wait to see the pics. 1 Share this post Link to post Share on other sites
sparkys toy 76 #18 Posted December 6, 2019 12 minutes ago, The Tool Crib said: When you click on reply to topic at the bottom it will say click to choose files. Click on that and ad photos there. One word of advice if you become a member you have a unlimited photo up loads. I thought I was a member Share this post Link to post Share on other sites
sparkys toy 76 #19 Posted December 6, 2019 Am I missing something? Share this post Link to post Share on other sites
stevasaurus 22,865 #20 Posted December 6, 2019 I think Randy is talking about the difference between being a member and a supporter. Being a supporter gives you more advantages like unlimited storage space for pictures. Check out being a supporter in the "General Talk" section. on the main page. There should be no pressure, and it is your choice. You are Welcome here either way. Take a look. 1 1 Share this post Link to post Share on other sites
sparkys toy 76 #21 Posted December 6, 2019 2 hours ago, 953 nut said: To load a photo you need to download it to your computer, open a reply or edit, click on the choose files and your computer will go to your photo file, select the photo and it will be added to your post. thanks now trying to get pix from phone to computer 1 Share this post Link to post Share on other sites
sparkys toy 76 #22 Posted December 6, 2019 2 hours ago, stevasaurus said: I've been gone all week, but maybe I can help if you can post pics. I do have some questions to ask...wait to see the pics. thanks stevasaurus once i split the second tranny every thing went well ,all gears that were damaged and both axles were interchangeable what a relief ,a bit confused by the gears on the 175 axles were less beefier than the 5060 transmission,and one side of the case had one axle bearing and the other had two and one axle had one half moon key and the other had a half moon key and a slot key .i think i bought a basket case but things are looking up.need to get needle bearings and seals and gaskets and i should be good to go.any tips on remove and installation of the axle needle bearings?. Thanks in advance for any help great bunch on this site hope to figure out how to get pix up soon 1 Share this post Link to post Share on other sites
cafoose 3,355 #23 Posted December 6, 2019 3 hours ago, stevasaurus said: I think Randy is talking about the difference between being a member and a supporter. Being a supporter gives you more advantages like unlimited storage space for pictures. Check out being a supporter in the "General Talk" section. on the main page. There should be no pressure, and it is your choice. You are Welcome here either way. Take a look. https://www.wheelhorseforum.com/store/ Share this post Link to post Share on other sites
sparkys toy 76 #24 Posted December 6, 2019 I definitely will do that Thanks fo the info 19 hours ago, sparkys toy said: You asked for it 1 Share this post Link to post Share on other sites
stevasaurus 22,865 #25 Posted December 7, 2019 Great talking with you today Sparky. 1 Share this post Link to post Share on other sites
