Rick Ferrucci 17 #1 Posted November 30, 2019 Hello, In getting my tractor ready for snow, I’m noticing that when I put the blade down, I’m not able to lift the front tires off the ground. When I move the lift lever back and forth, it bucks like it wants to lift the front, and it does take the weight off the front, it just doesn’t lift high. It’s got fluid, at least the dipstick indicates it does. The tractor moves around fast, but I only have flat ground. Does anyone have any ideas as to what I might check? Thanks for your help. Rick Share this post Link to post Share on other sites
pfrederi 17,875 #2 Posted November 30, 2019 What model tractor are you using. Is this a new issue??? Some tractors only generate down force with a special link. Share this post Link to post Share on other sites
Rick Ferrucci 17 #3 Posted November 30, 2019 My tractor is a GT 14. It normally does have down force to the blade. One thing more though. I’ve had the tractor for six years, and I’ve never changed the filter. I only use this tractor to plow snow, so I’ve probably only put maybe 50 hrs on it if that. Share this post Link to post Share on other sites
953 nut 55,773 #4 Posted December 1, 2019 Here is the manual for your Sundstrand hydrogear transmission. There is a over-pressure valve that could be in need of servicing or a new spring. Share this post Link to post Share on other sites
Rick Ferrucci 17 #5 Posted December 1, 2019 Thank you for this manual, I need some information on servicing, and maintaining this. 1 Share this post Link to post Share on other sites
