The Tuul Crib
Charger 10 refresh
ebinmaine
Lookin forward to seeing this one run and drive!!
The Tuul Crib
 Me as well. Everything looks good so far I have a really good running 12 horse to put on it. Clean up and no Resto.
Stepney
I had a Charger 9 and really liked the little Tecumseh engine. If it has any hope I'd try and run it myself. Mine always started really easy no matter the weather, and was better on fuel then a Kohler.
Looks like an easy project for sure.
Achto
Chiming in to follow along :popcorn:
WHNJ701
scuff and buff, scuff and buff
The Tuul Crib
I did the hood some already with
wd 40 and some 360 grit l have and
it doesnt look bad at all!
ebinmaine
Pictures boy!!
Where's the pictures???
tom2p
anyone use scotchbrite pad instead of wet sandpaper ?
I often use scotchbrite pad and WD-40 on metal surfaces ... unpainted motorcycle exhaust pipes ... etc ...
scotchbrite pads are available in different levels of abrasiveness
might work well on the Wheel Horse body parts ???
WHNJ701
I used scotch pads and paste wax on the 701 the following year I wiped all the metal down with old drain oil on a rag and left it sun.  it's a sharp looking tractor
rjg854
@jabelman  where's the :text-coolphotos:
Pullstart
@ebinmaine I climbed the Eiffel Tower today.  And I have as much proof as Randy has!  :ROTF:
  • Haha 3
The Tuul Crib
 OK so I making a little progress today I tightened up all the internals on this 12 horse. Honed it, new rings, lapped the valves. Should be good to go! I did clean  it up some. The tires hold air. The deck for this one is solid. Absolutely no rust so
a little clean up there should do it. Might
need blades.
The Tuul Crib
 I ended up tearing this tractor apart and today was 55° so I took it outside and pressure washed every piece. Now I've started the process of sanding with WD-40. Going to clear lacquer everything and put her back together !
Pullstart
Make sure to clean that WD40 real good before you spray the clear!  Soapy water is a great wet medium too :handgestures-thumbupright:
WHNJ701
fish eyes!
MikMacMike
when there rust permiating the surface I have had great success using rust converter. It wipes off paint and raw steel but turns the rust into I think a black oxide or something. With a few coats you quickly sand and primer. I prime till all pits are level with surface then use I good industrial machine paint or one of the tractor manufacturer company paints. Might has to alter the red colouring a bit to match the wheel Horse colour.....Hmmm Massy Ferguson, International. hmmmmmwho else had red tractors?
N875ED
I purchased a quart of "International Harvester" red from Rural King. I removed the side decal from the hood from my 312-8 (to get the virgin paint color never exposed to sun and faded) then put a dab of it on this new surface. After drying, it is nearly impossible to see the difference between the two colors, so it's as close a match as one can reasonably get.
The Tuul Crib
OK so here's an update on the charger
10s . Was going to do a patina look but between the two tractors some of the parts needed some repairs. So in order to make the repairs I had to do some welding. So I figured I would have to do some repainting as well and decided to do a complete repaint got started cleaning parts today.
Plus I have a 12 horse in my collection that I am going through and doing a quick cleanup with new rings and honing the cylinder and lapping the valves.
Pullstart
ADD.  Ooooh Shiney!
The Tuul Crib
Making a little progress slowly but surely on this one the transmission took the longest the motor was done before that now I just got my dash decals from
@Vinylguy! Greatly appreciate it Terry. Got it all together and I actually have the original cigarette lighter in working condition! All I had to do was clean it up a little.
Edited by The Tuul Crib
  • Excellent 4
The Tuul Crib
Got everything buttoned up today as far as connections ground wires run throttle and choke are connected.Just finished on the wiring for the day and will have this thing running tomorrow. Totally psyched!
so much so I broke out my small
Bottle of Tennessee cheer!!
  • Excellent 4
  • Haha 1
  • Heart 1
The Tuul Crib
Got er running on her own power today. My sweet 16 has come to life! And it moves!!
ebinmaine
Can't watch the video but that's super awesome
