Wheelhorse Wes
Rj transmission casting numbers
Wheelhorse Wes
So.....my buddy Joe from Iowa  (whose on here....Jennifer) sent me pictures of threads on red square about RJ transmission casting numbers.
my 1960 suburbans have casting numbers
G13-9
G17-9
my RJ is N17-8
so....according to the A-1(January) B-2(February) so does this RJ of mine mean February 17 1959???? Even though it is casted 8 according to the letter sequence would force it into a 1959 tractor....and on top of this the gentleman I bought this RJ from bought it from the original owner who told him he bought it brand new in 59....
WHX??
This  might  be better in the tranmissions & axles section so I am sure when @stevasaurus sees it he will move it there and hopefully answer your question. :)
Wheelhorse Wes
Oh sorry. Yes I should have put it there sorry guys
The Tuul Crib
 Just opened up the instruction manual and parts list that I just picked up and have the parts list and parts numbers
wallfish
45 minutes ago, Wheelhorse Wes said:
N17-8
The theory is they didn't use the letter I because it could be confused with the number 1 but the N still puts it at 13. Not sure now if there's a B to be confused with 8 but hopefully someone knows
It's possible to buy a tractor built in late 58 in 59. It's possible the casting made in late 58 would go on a tractor built in 59.
Either 58 or 59 they are all badged RJ-58 and all are the same tractor with a few very minor exceptions like the solid seat pan and some had a 1960 height adjuster added to the lift lever.
  • Excellent 2
Wheelhorse Wes
This is going to restored as a 59’ I’m going to believe the gentleman I bought it from who bought it from the original owner.....I was just confused about the first letter as the N....the numbers on the transmission are clear I can read them fine. Thanks for everyone help..WES
buckrancher
The cast numbers and letters are a casting date from the foundry they have nothing to do with when the tractor was sold the po could have purchased the tractor in 59 that does not mean it's a 59
could be a leftover from 58
brian
stevasaurus
@buckrancher  @wallfish  after giving this some thought about the "N", is it possible that they also did not use "L"???  That would make the "N" December.  :eusa-think:
Lane Ranger
Not sure what each of the 12 month codes are for the RJ and Suburban three piece transmission’s are  but I took pics of four I have here.   Like Steve days ( who has seen a few of the also) the center piece of the three piece had a code placed on it when it was cast at the factory.  I have an early 1958 with No Code , a 1959, a 1960 and another 1959. Steve and I decided to use a good 1960 center on a 1958 RJ transmission rebuild ( See Steve’s. : So You Want to Redo a Three Piece Transmission post) of a couple years ago. Note the % mark on the 1960 case - no telling what that was about.
Edited by Lane Ranger
stevasaurus
Couple of those are pretty rough Lane...brings back some memories Mate.  :occasion-xmas:
Wheelhorse Wes
Thanks everyone for the information on the transmission casting numbers. So between you me and Santa Claus it’s not going to matter if I restore this tractor as a 1959 then. Thanks everybody. Wes
thumbs up
wallfish
thumbs up
Certainly not!
Lane blew up my "B" theory. By the way it looks like an 8 LoL
  • Haha 1
Wheelhorse Wes
It’s an 8
stevasaurus
You may be safe to assume that N (December) 17th 1958 transmission ended up on a RJ that was put together in 1959, but you would be positive if that last number was a 9 and it was the original transmission.  :occasion-xmas:
